ASP Sauce - How accurate is the customized peak and taper?
Old 01-17-2007, 06:58 AM
pitchS4's Avatar
Default ASP Sauce - How accurate is the customized peak and taper?
Guys who have customized their peak and taper with ASP how close to what you specified is the actual boost? For example if you wanted 16 peak taper to 12 (K03s) does it spike to 18 or hold true to 16.
I am thinking of getting something mild to help save my K03s (75K miles on them). Can I put my confidence in the customized software or am I better off getting an MBC, or even a mild chip like MTM.
Old 01-17-2007, 07:14 AM
wagongotya's Avatar
Default if you try and save ko3's they will die, if you try to kill them they'll live forever....
the turbo lady works in misterious ways
AVANT S4 KING's Avatar
Default Its gonna be pretty darn exact, assuming you dont have a boost leak. I'd recommending calling them
Keep in mind that what your boost gauge shows isnt exactly a scientific measurement, but if you were to log, the highest requested boost should not exceed whatever value they set in the file the give you.
Mark and Frank are very helpful. Call them and they will explain how their software works in a detailed manner that is understandable to the common person. Their standard tune runs very strong and very smooth. Its like MTM and GIAC had a lovechild.
As for the MBC, I had a VAST MBC (parallel) in my car when I ran GIAC. I left it in when I switched to ASP, but had it turned up past what the ASP spikes to. Anyway, I used to get a strange overspin sound even at sub 0psi boost levels. After I took the MBC out, the sounds stopped. Also, the car feels better than before (although with the temperature dropping and me installing a new coolant temp sensor recently, I cant say what the biggest factor is)
Needless to say, I think mine was leaking.
Old 01-17-2007, 07:17 AM
pitchS4's Avatar
Hah yeah i figure they are going to die eventually i just hope it's when I have more money
Old 01-17-2007, 07:19 AM
wagongotya's Avatar
leave her a stock boost for a while then
Old 01-17-2007, 07:24 AM
pitchS4's Avatar
been there for a while i'm getting bored. if they blow soon there is always mastercard
Old 01-17-2007, 07:25 AM
Senior Member
S4Poor/deux@Curbside's Avatar
Soooo true.
Old 01-17-2007, 07:26 AM
Senior Member
100% spot on. I got exactly what I asked for. No deviations.
Old 01-17-2007, 07:28 AM
Ram@S4-MTM's Avatar
New K04 replacements for your dead K03's - Priceless
Old 01-17-2007, 07:33 AM
wagongotya's Avatar
LMFAO, well done sir!!!
Quick Reply: ASP Sauce - How accurate is the customized peak and taper?
