What does the esp button do?
Old 08-19-2002, 01:41 PM
  #21
Elder Member
George @ BostonAudi's Avatar
Default It absolutely turns on, as soon as you hit the brakes...
It can't perform miracles... If you've already lost it before you hit the brakes, it won't save you. If you are off the brakes, though, it stays off.
Old 08-19-2002, 01:50 PM
  #22
New Member
quattroinAK's Avatar
Default it may activate while the brake is depressed, but i have never had to manually turn it off again
after using breaks and i turn it off quite often in the winter to have some fun. the only time i have to reset it to off is if i turn the car off then it defaults to on when you re-start the car.
maybe mine is broken, but it works great when i leave it on. it has saved my *** many times, but i have been the ditch more than once with it off.
Old 08-19-2002, 02:15 PM
  #23
Senior Member
George Burdell's Avatar
except that normal streets don't have run-off... so you just wreck.
Old 08-19-2002, 02:46 PM
  #24
Member
bioman's Avatar
It kicks in well shy of the limit in the situation I described though
Old 08-19-2002, 11:05 PM
  #25
New Member
audidealerholland's Avatar
Default you can !!!
By phussing the button you shut the esp off, BUT.... if you touch the brake pedal it automatically turns itself on.
Old 08-20-2002, 09:51 AM
  #26
Senior Member
Auto Union Jack's Avatar
That is the problem. Some drive either full throttle or full braking making ESP kick back in.
Old 06-15-2019, 06:41 PM
  #27
Melchior's Avatar
How does it work? When I push it nothing happens!
s4ms4
S4 (B8 Platform) Discussion
08-18-2010 05:55 PM
SlehStar
07-23-2002 05:37 AM
jhood
11
02-12-2002 04:48 PM
KenRS4
22
04-03-2001 12:27 PM
Quick Reply: What does the esp button do?
