what should i use to take off the bolts between the tranny and driveshaft, regular hex or ball hex?
Old 04-05-2007, 07:29 AM
  #11
inliner311's Avatar
Default no but autozone does....the ones you have to put it into a wrench
I would like to find some triple squares you can put directly onto a 1/2 or 3/8 drive ratchet.
Old 04-05-2007, 01:43 PM
  #12
Junior Member
Rolf's Avatar
Default I bought that set from autozone, you can make a home-made socket like I did..
Just cut the triple square bit to the size you need with a dremel cutting wheel or air cut off wheel if you have one, then epoxy or JB weld the bit into a spare (or go buy a single socket) socket. instant triple square socket I also did this with a 17mm hex key for the axle shoulder bolt. Sears sold an actual L shaped 17mm hex key. So I just cut about an inch and a half off the end with my air cut-off wheel, and jbweld'ed it into a spare socket that fit it.
pink shrimp
9
01-07-2008 06:05 AM
germantoy
Audi Original "S" Cars
01-27-2006 01:42 PM
sochi
Audi 100 / A6 (C4 Platform)
10-13-2004 04:47 AM
q20v
03-17-2003 02:10 PM
Quick Reply: what should i use to take off the bolts between the tranny and driveshaft, regular hex or ball hex?
