While the engine is out...
Old 03-13-2008, 11:00 AM
Smarty39's Avatar
Default While the engine is out...
What seals/gaskets (that I don't already have) should be replaced. I have the following waiting to go in:
valve cover gaskets
cam plugs
cam adjuster gaskets
crankshaft seal
crank seal plug
TIA
Old 03-13-2008, 02:29 PM
Gray Bush's Avatar
depending on milage I would strongly consider the rear main seal.
Old 03-13-2008, 02:59 PM
radron26's Avatar
k04's+fueling......
Old 03-13-2008, 03:28 PM
Member
Skyler@Achtuning.com's Avatar
^2nd
Old 03-13-2008, 03:36 PM
ChucktownS4's Avatar
2nd, plus clutch, i just did my clutch 5 months ago then the turbo went 2 mnths later
Old 03-13-2008, 04:01 PM
Smarty39's Avatar
Default I guess I should've went a little more in depth with my post lol...
Yes, I am going full Stage 3 (VAST everything!)...and I forgot to add the rear main seal to my list, but I already have that as well...anything else as far as seals/gaskets? I'll ovbiously be doing the TB and all that good stuff as well.
Smarty39's Avatar
no clutch as I'm a tip...but am getting an upgraded TC
Old 03-14-2008, 07:55 AM
HdiaS4's Avatar
Default are you getting a new turbo gasket kit?
if so here are couple things that you could also do.
o-rings in all coolant pipes, back of the head and into the block.
clutch line btw slave to master cylinder.
updated slave cylinder.
Old 03-14-2008, 08:03 AM
tru tru! )
Old 03-14-2008, 08:16 AM
HdiaS4's Avatar
lol didn't see you were a tip.
12vWhat
Audi allroad
09-21-2011 02:09 PM
QuattroFan02
11-15-2007 07:41 PM
HdiaS4
17
09-05-2007 01:12 PM
SFexBOY
06-08-2007 05:47 PM
MarkPan
11-13-2005 02:57 PM
Quick Reply: While the engine is out...
