why would the axle be hitting the sway bar end link?
Old 03-20-2008, 03:26 PM
s4boosted's Avatar
Default why would the axle be hitting the sway bar end link?
there isnt very much clearance down there and it makes a rattling noise everytime i hit a bump. The end link looks stable but it is much closer to the axle on the driver side than the passenger side. Btw, i am talking about the rear of the car
Old 03-20-2008, 03:54 PM
wagongotya's Avatar
oem or metal replacements?
Old 03-20-2008, 04:08 PM
s4boosted's Avatar
Default as far as i know they are oem. but not exactly sure. its really obnoxious.
should i take the wheel off for a better look?
Old 03-20-2008, 04:20 PM
BlackS4tt (Josh)'s Avatar
ive had the OEM metal links for several years and never had clearance issues...
Old 03-20-2008, 04:21 PM
Member
MCH 2.7t's Avatar
Default Are you sure its the end link?
What shocks and springs are you using? With some spring / shock combos, the spring perch can make contact with the axel.
May be a long shot, but worth checking
Old 03-20-2008, 05:04 PM
hans j's Avatar
Is your subframe or link bent? Or is the ball joint worn out on it?
Old 03-20-2008, 06:46 PM
s4boosted's Avatar
i haven't been able to tell if anything is bent yet. hope its not the freaking sub frame. good grief
Old 03-20-2008, 06:47 PM
s4boosted's Avatar
stock suspension. i'm pretty sure its the end link. the vertical bar that the sway bar connects to.
cap
07-14-2009 11:08 AM
KillA6
01-06-2009 07:28 AM
onebadstage3s4
9
06-11-2007 04:33 PM
Justin517
01-28-2005 04:49 PM
Quick Reply: why would the axle be hitting the sway bar end link?
