wierd problem. could my ecu be bad or what??
So I hooked my car up to a vag scanner and it said the ecu was 4z7 907 551 s. BUT when I looked at my ecu it said 4z7 907 551 r. Could that be a sign my ecu is bad or the vag scanner is bad?
It is extremely slow. I'm only seeing like 4 to 6 psi on brand new turbos. Its throwing all types of codes. All o2 sensors, both cam sensors, maf sensor, and secondary air pump.
That's really all the background I have. I bought the car like this. At light throttle is drives fine even at moderate throttle it is pretty quick. But when I put the peddle to the floor the wind is blowing me faster than the car accelerates.
You need to scan step by step. Prefer a realtime monitoring VAG device or whatever.
Can you contact the previous owner? Ask him specific what happend with the car? Any background is worth something on the car.
If that is'nt an option, pressure leak test, N75, refresh filters / oil / fluids, make sure everything is as it should.
From my experience, having the wrong type of sparkplugs or plugs that are worn out, it can do pretty much weird **** with a car like that. Garage accidently provided me Bosch sparkplugs instead of NGK's. It took 2 days when the car started to throw random Cells.
Stroker//S4
Audi Original "S" Cars
07-27-2006 02:50 AM
A4Jared
11-27-2004 07:58 PM
boostedTT
08-18-2004 05:03 AM
