Yaw Rate Sensor. - AudiWorld Forums
Yaw Rate Sensor.
Old 06-09-2014, 07:41 PM   #1
Default Yaw Rate Sensor.
A few days ago my ABS light came on. Today it happened again. Reading the ABS codes via VCDS brings up this:
Monday,09,June,2014,21:23:38:30473
VCDS Version: Release 12.12.2 (x64)
Address 03: ABS Brakes Labels: 8D0-907-389.lbl
Control Module Part Number: 8D0 907 389 E
Component and/or Version: ABS/ESP allrad D46
Software Coding: 04395
Work Shop Code: WSC 01234
VCID: 356F2A100F367FB6781-515A
1 Fault Found:
01542 - Yaw Rate Sensor (G202)
27-10 - Implausible Signal - Intermittent
I recently had the rear lower seat out, and put it back in after cleaning out some gunk from the kids. Is it possible that the force to shove the seat back into place did something to the yaw sensor? I've had the ABS/ESP go out about 3 or 4 times before in the last 9 years. Is the sensor just finally calling it quits?
GomerPyle is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
SQ5 Ride? NealcpLA Q5/SQ5 MKI (8R) Discussion 49 10-08-2015 01:21 PM
T rated tires for Q7 audiblack73 Q7 Discussion 1 09-30-2015 04:15 PM
Question about fuses, cruise control and steering wheel havocgb A6 / S6 (C5 Platform) Discussion 5 09-25-2015 05:50 PM
2013+ S4 Reliability smallbizwhiz S4 (B8 Platform) Discussion 7 09-24-2015 12:31 PM
2016 Q7 5 Star Safety Rating pcullen Q7 MKII Discussion 0 09-02-2015 01:54 PM
Tags
abs, audi, b8, sensor, yaw
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
