Ash Tray? - AudiWorld Forums
S6 (C7 Platform) Discussion Discussion forum for the C7 Audi S6 produced from 2012 - Present
Ash Tray?
Old 01-14-2014, 07:30 AM   #1
Default Ash Tray?
Hi there,
Anyone know if there should be a ash tray in the front? I just bought a new S6 and see what looks like ashtrays in the back, but then just an empty box in the front. There is a Ashtray page in the owners manual, but mine is just an empty box, nothing like how it looks in the owners manual. It also shows a cigarette lighter next to the ashtray which is also missing. How do yours look? Is it missing a part?
Thanks.
-Dave
davideisenva is offline   Reply With Quote
Old 01-14-2014, 07:46 AM   #2
snagitseven's Avatar
In the U.S. at least, starting with the MY2013, in the C7s Audi did away with the ashtray/cig lighter/12v socket in lieu of the covered storage bin. A couple of folks back in the summer of 2012 reported they were able to specify the ashtray at order of a MY2013 but I haven't heard of that since. I suspect the manual is showing what may still be available in other locales.
As you've discovered, there is still a 12v socket in the center console and one on the back of the console facing the rear.
snagitseven is offline   Reply With Quote
Old 01-14-2014, 10:21 AM   #3
Hi there,
Any suggestion on if I can order the part, regardless of whether or not the cigarette lighter works? Do you think I would need a complete revision to the center console?
Old 01-14-2014, 02:38 PM   #4
Default Safety equipment
The empty box is part of the safety equipment! Replace it at your own risk.
DD1546 is offline   Reply With Quote
Old 01-14-2014, 02:43 PM   #5
Brooklyn's Avatar
Part of the safety equipment? I too was stunned when, after picking up my A6 in FL and getting ready to make the drive back to DC, I opened the "storage" bin only to discover there was no 12v socket to plug in my detector.
Brooklyn is offline   Reply With Quote
Old 01-14-2014, 02:58 PM   #6
Quote:
Been there, done that! Had to use the outlet in the center console and run a wire from the detector under the side of the transmission tunnel cover; or you could have a direct power supply installed by a stereo shop you trust.
rickymp is offline   Reply With Quote
Old 01-18-2014, 04:50 PM   #7
Default Ashtray Installed!
Hi all,
So I went back to the Audi Dealer and showed them the cigarette lighter on a used A6 on the lot. They then ordered that same Ashtray by part number. I now have a non-working cigarette lighter, and a perfectly fitted ashtray. There was no wiring for it, and if I wanted them to wire it they would basically have to make their own connector for the harness and run in back. It took roughly 1.5-2 hours of labor. The part cost $200 (I am asking Audi for reimbursement, we'll see) + $160 for the labor. The only downside is the cigaratte lighter doesn't work, but now I no longer have to have a cupholder ashtray taking up one of the two center cupholders so that's good! Just to let you know, if you push the dealer hard enough they will order the actual ashtray, and it is possible, don't them sell you the Audi Cup Ash Tray.
Just figured I would share.
-Dave
Old 01-18-2014, 08:26 PM   #8
So, if understand correctly, you spent $360 (with no guarantee that AOA will reimburse) to replace the storage bin with an ashtray and still ended up with no working 12v outlet? Wow. Also, what is a "cup holder ashtray"? Mine does not have anything like that, just the covered two cup holders with the forward storage bin in lieu of an ashtray/12v outlet (thankfully). Maybe it's a Premium Plus thing?
Old 01-18-2014, 08:37 PM   #9
Brooklyn's Avatar
Yeah, I'm not quite sure I understand what you did there, unless you just really wanted an ashtray and didn't really care about the outlet one way or the other. I definitely don't get why you'd think Audi would reimburse you but good luck!
Old 01-18-2014, 08:41 PM   #10
tenspeed's Avatar
Quote:
http://www.ebay.com/itm/AUDI-ASH-TRAY-CUP-HOLDER-/141165494224?pt=LH_DefaultDomain_0&hash=item20de1e7fd0
tenspeed is offline   Reply With Quote
Thread Thread Starter Forum Replies Last Post
convertible top rear latch wont manually open bigemike A4 Cabriolet (B6 Platform) Discussion 2 02-18-2017 06:12 AM
Ash tray: anyone successfully modified this into something useful? (x-post to S4 forum) [not Steve] Trac A4 (B5 Platform) Discussion 4 12-26-2000 05:52 PM
Back Seat ash tray? gonzalowitz A4 (B5 Platform) Discussion 8 08-15-2000 11:21 AM
Help 2000 Ash tray stuck. peter A4 (B5 Platform) Discussion 0 01-24-2000 09:57 AM
Help 2000 Ash tray Stuck Peter A4 (B5 Platform) Discussion 2 01-24-2000 07:33 AM
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
