Baseline Dyno Graph
Baseline Dyno Graph
Hey guys and gals. Finally got a legible copy of my Dyno results from last month. Figured I'd share them with and see what everyone's thoughts are.
The highlights:
Max Power: 410.39
Max Torque: 449.24
Run Temp: 90.76 Degrees
Run Humidity: 38%
The highlights:
Max Power: 410.39
Max Torque: 449.24
Run Humidity: 38%
S6, what does the factory claim for output on this engine?
I believe I read somewhere on the forum that the bump from 420 to 450 is just on paper. Nothing has changed in the engine, they were just way too conservative reporting for MY13-15. Not sure if that's true but it could very well be.
Right, just like Audi says 0-60 is 4.5s but Car & Driver measured 3.9s and supposedly even 3.7s pre facelift.
For comparison sake a Stage 1 RS7 running 10.6 in the quarter should be about 2.3s !!!!
I need to make some time and find some space to do some VCDS acceleration measurements.
410 at the weels means about 10% less than crank and torque 406 > 450??! Amazing.
Correct. No tune......yet. I realize some manufacturers Dynos can read higher than others. Even so, I was still happy with the numbers. Can't wait to see what they are after a tune. Hoping to do APR ECU and TCU tunes, possibly downpipes at the same time, very soon.
Right in line with expectations given that the car's actual measured performance suggest that the motor's true output is right around 500 CHP.
