S6 (C7 Platform) Discussion Discussion forum for the C7 Audi S6 produced from 2012 - 2017
Brake parts
Old 08-06-2016, 04:09 AM
thodgez28's Avatar
Default Brake parts
Looking for the part numbers for disc Italia ceramic non dust pads....can anyone help? Also looked at Adams rotors and at other aftermarket rotors.......1300 for front and rear? Can anyone tell me why it ranges from 300 to 800 for front rotors? Are Adams better? If I add slotted and drilled won't I get noise when I stop?
I know there is probably a thread on this already but I can't find it.
Thanks for the help in advance
Old 08-08-2016, 06:28 AM
gee2dasahn's Avatar
I got my Disc Italia Ceramics from Brake World. Just look them up by make and model. As for "non-dusting" they still dust a bit, just a lot less than the OEM pads.
No experience on the Adam's Rotors, but heard positive things. Not sure where you are finding a $300 option for front rotors. OEMs online were almost $300 a piece (which is what I went with). I know that the fronts have a "floating" hat assembly so I'm sure that adds to the cost. Pricing is anyone's game, whether it be driven by quality, customization, branding, or a combination of them all.
As for drilled or slotted, I don't believe there will be significant concern for additional noise. On the flipside however, if you are looking for less dusting, either option would not be optimal.
Best of luck with your decisions and the brake job!
Old 08-08-2016, 03:12 PM
thodgez28's Avatar
Thanks 👍
Old 08-12-2016, 07:53 AM
2013 rick's Avatar
Originally Posted by thodgez28
Thanks 👍
front oem rotors are on ebay for $175 each.
Old 08-20-2016, 09:23 PM
MP4.2+6.0's Avatar
Just visiting, but FWIW several things in thread don't sound right. If a current S6 w/ 400mm rotors, those should be the semi floating ones with the aluminum hat. Not supported by aftermarket, so eBay stuff will be expensive heavy doorstops unless they are OES (and maybe already glowing...). Adams doesn't have them either, contrary to website. I checked into it for 2015 S8 w/ same 400mm front set up as the other various 4.0T's--emailed directly and got that answer back from Adam. Basically dealer only. Only other possible might be Brakeworld, if they are still doing the pretend DiscItalia brand rotors that basically seems to be machined OE parts, or at least was with the D3 A8s for my prior W12. Rears are a lot easier with the conventional cast rotors.
Old 08-21-2016, 01:01 PM
2013 rick's Avatar
Shouldn't be too hard to check as they are being sold by an Audi dealer ( I think )
Old 08-21-2016, 01:17 PM
gk1
gk1's Avatar
JAdams doesn't have them either, contrary to website. I checked into it for 2015 S8 w/ same 400mm front set up as the other various 4.0T's--emailed directly and got that answer back from Adam. Basically dealer only.
FWIW apparently Adam does drill and slot OE rotors for S6 A8.
https://www.audiworld.com/forums/s7-.../#post24785224
Old 08-22-2016, 01:57 PM
goliath1's Avatar
Correct...I got 400mm slotted and dimpled (they won't drill) for my 2013....then 3 months later I traded it in...oh well
bpp
Q5/SQ5 MKI (8R) Discussion
13
07-21-2018 06:21 AM
RodriguesV
12-30-2017 04:25 AM
biggsie
Audi allroad
11
10-20-2007 07:32 AM
egp320i
9
06-02-2005 07:35 PM
AaronC
07-31-2001 08:10 PM
Quick Reply: Brake parts
