S6 (C7 Platform) Discussion Discussion forum for the C7 Audi S6 produced from 2012 - 2017
C7 S6 LED Headlight Coding
Old 08-12-2014, 11:51 AM
Taylor Shaw's Avatar
Default C7 S6 LED Headlight Coding
Hello,
I must have made a mistake in Vag com when changing settings on my headlights. I meant to make the DRL strip stay on all the time, but now the headlights are on all the time, even during daylight. Does anyone have the stock code for a 2013 S6 with LED lights?? Thanks in advance!
Old 08-12-2014, 12:04 PM
Richard Solomon's Avatar
What module did you muck with? Please tell me you ran and saved an Auto-scan before fiddling around....
Assuming you futzed with Central Convenience, it's not that simple - the coding depends on numerous options so there's no "stock code" per se.
Which instructions did you intend to follow?
Old 08-12-2014, 02:22 PM
I am an idiot.. I had saved the auto scan, just couldn't find where. All is well now. I was messing with the central convenience just to make the DRL strip on with headlights as well just because it looked cool.. Not worth messing them up and having them not function correctly at all haha! Thanks for the reply!
Old 08-12-2014, 03:00 PM
Whew, otherwise I was gonna say you were Norbert....
Just make sure to do before and after screen shots or scans, etc and you *SHOULD* be fine with most changes.
Old 08-12-2014, 06:35 PM
Xtek's Avatar
The DRLs do run when the headlights are on. They're brightness is dimmed a bit which is an easy change with VAG-COM.
2k6blacka8
20
06-25-2023 06:38 PM
ScooterWard
12-02-2010 05:03 PM
Redneck Truck
09-22-2010 08:10 PM
MARLYMARL617
12-18-2007 06:13 PM
uropn2
04-08-2003 06:18 PM
Quick Reply: C7 S6 LED Headlight Coding
