Can you get tire pressure
No, it's an indirect system so it recognizes a change, not absolute values.
The A8 may still have the direct system that would offer values.
The C7 with it's passive TPMS will display the individual tire that's low but with no PSI readout. It usually takes about a 7 PSI drop from the driver's MMI setting before it displays an alert.
Just wanted to chime in here. I am glad Audi is using the "rotational computation" type sensor. The direct sensors that mount inside each wheel on the valve stem are more trouble than they're worth. I have heard about batteries dying right after the warranty runs out, water getting into the electronics, tire shops destroying them when they mount/dismount tires, etc. Not to mention the added expense of buying an additional set of sensors if you're running winter wheels.
its not 100% accurate anyhow, every car that ive had with it is all the same. my current cayenne s has it and its not accurate, when I use a snap-on digital tire gauge it always reads different.
The data geek in me likes the idea of an exact digital readout - and I suspect most of them can be calibrated, so yeah once you put your NIST-traceable pressure gauge on there you'd wanna calibrate the in-car system I suppose :P
I'm fairly certain the A8 is the only model that still utilizes the in tire sensors, however, I am not sure if it is all of them or if it is an option. I know the previous model A8's would give you not only tire pressure for all 5 tires but internal temperature as well, the temperature readout is a quick way to find out if you have a brake issue, like a stuck caliper or even a bad wheel bearing, if one tire is substantially hotter than the rest it is a sure sign that something is wrong in the area of that wheel. Now I am curious, I am going to look into the newest A8's and see what kind of info you can get from the TPMS system.
I suspect there's a TPMS receiver somewhere and a coding for MMI to use it vs the ABS one...but maybe I'm just an optimist.
I have three different types of gauges... none of them ever match. I've always been confused as to the acuracy, or lack of, with tire pressure readings.
