Check Engine Light P0018
2012 Audi A6 3.0T:
Anyone have this CEL P0018 before?
Per VAG COM: Crankshaft Position Camshaft Position Correlation Bank 2 Sensor 'A'
I had the CAM sensor replaced but problem persists. Had the wiring checked and they tested out good as well. Last thing to check tomorrow is timing. Anyone run into this before?
Thanks
Thanks
P 0018 is the code for two sensors. It could be the Crankshaft Position sensor or wiring if you're lucky. Here's a couple of links that cover many other possibilities.
P0018 Audi Crankshaft Position Camshaft Position Correlation Bank 2 Sensor 'A' OBDII Engine Light Trouble Code | Engine-Codes.com
P0018 Crankshaft Position - Camshaft Position Correlation (Bank 2 Sensor A)
Jon Clay
Inline-5 Discussion
9
03-08-2005 07:20 AM
