The DEFINITIVE Definitive Word on the Throttle Lag Issue(?) - AudiWorld Forums
S6 (C7 Platform) Discussion Discussion forum for the C7 Audi S6 produced from 2012 - Present
Old 06-04-2014, 09:04 AM   #1
Default The DEFINITIVE Definitive Word on the Throttle Lag Issue(?)
Just picked up my car from the 15k service. Also had TSB 2035235/2 performed, as my EPC light blinked on on the way to the dealer. The say this update addresses both the EPC light and the hesitation. However, I forgot to ask for an actual copy of the TSB, and can't find it online.
It works. I thought it was in my head at first, but it really does seem to have eliminated the lag. I accelerated several times from a rolling stop, and the lag was gone. I still need to try it out on my go-to test spot, but I think this did the trick.
My advice is to get this TSB done immediately if you have the lag issue.
Also, does anyone have access to the TSB? I'd love to read a copy of it.
nobbyv is offline   Reply With Quote
Old 06-04-2014, 09:31 AM   #2
Default Can't find TSB
Could you please ask the dealer for the TSB #. I can't find any ref. Is this different from the TSB that remapped the tranny to get rid of harsh downshifts? I had that done about 7 mos ago and it helped the downshifts but not the "lag". Thanks.
DD1546 is offline   Reply With Quote
Old 06-04-2014, 09:43 AM   #3
Quote:
This is NOT the same as the tranny update. The only number they have is the update number posted above. They don't actually call it a TSB, which may be why it's not available online. They called it a "software update as per bulletin 2035235/2".
Old 06-04-2014, 09:52 AM   #4
MalibuCANE's Avatar
I just emailed my sales guy at the dealer to see if I can get this done. I will be so psyched if this works.
MalibuCANE is offline   Reply With Quote
Old 06-04-2014, 10:04 AM   #5
Quote:
If it works, it's like a whole new car. I was seriously considering selling my S6 due to this issue.
BTW, my SA said this update was released in late January 2014, so MAY explain why some 2014s don't seem to have the issue. Can you confirm your build date?
Old 06-04-2014, 10:35 AM   #6
MalibuCANE's Avatar
I picked mine up in early November of last year. My car was in for 500k service recently but I guess they didn't do the update.
Old 06-04-2014, 10:58 AM   #7
My understanding from my SA is this update is not like a TSB or a recall. She said something about it being "on the technician side". They will only apply it if you complain using the magic words: in this case, EPC light. They won't automatically apply it to every car they're doing routine maintenance on.Unfortunately, the EPC light isn't something that you can fool them on; it throws a OBD-II code which they need to verify. I think a lot depends on your relationship w/ your dealer. Worth a shot, though.
Old 06-04-2014, 12:42 PM   #8
MalibuCANE's Avatar
Yeah, the dealer said they have to check the fault codes to see if this update applies. My appointment is Monday so I hope it isn't a waste. I have to convince them to update it somehow.
Old 06-04-2014, 12:48 PM   #9
You may be able to find someone with a VCDS local to do a quick scan before then to let you know if its worthwhile or not. Just be sure they don't clear any faults they find.
Of course, it's also always possible you can talk them into the update even without the fault, too. Good luck.
Old 06-04-2014, 12:51 PM   #10
MalibuCANE's Avatar
I have one but since I have never seen the engine light I have to assume the fault code isn't present. i am being up front with them and I will see where that gets me.
Thread Thread Starter Forum Replies Last Post
Yes, another ABS thread YukonLT A4 (B5 Platform) Discussion 3 01-29-2016 12:36 PM
I have some fault codes and an engine light car stalled turned off saifxnyc A6 / S6 (C6 Platform) Discussion 9 11-30-2015 01:32 PM
Throttle cut out saga urojohn S4 (B8 Platform) Discussion 2 11-01-2015 05:02 PM
New Q7 2015 TDI slight shimmy dealer calls it road feedback? Quetzal Wheels & Tires Discussion 3 09-23-2015 08:50 PM
Clutch is not fully disengaging RTnDL A6 / S6 (C5 Platform) Discussion 0 09-07-2015 12:17 PM
Tags
24702599, a6, acceleration, audi, car, current, due, epc, lag, problem, q7, s6, software, supply, update
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
What's your question?
Send
