How-to: Installing brake pads on an S6/7
#21
- Take it easy for a few hundred miles
- Bed them in with heat, followed by letting them cool completely
#22
I understand the impracticality of bedding brakes on millions of new vehicles every year....so why is it so important to do? seems contradictory. millions of new cars never have braking issues....
one of life's mysteries I guess...
#23
Most drivers won't bed in new pads properly (multiple hard stops until fade is setting in, followed by a proper cool-down period) but then most drivers don't use all their brake's capability either. Those that do (drive in hilly areas, for instance) are the ones that will experience issues.
#24
#25
Deer hunter thanks again for the write up. I just did my fronts. I ended up reusing the spacers. Just put a little silicone on them. I still need to do the rears. 37,000 miles on the s6 fronts had 5mm of pads left. Side note, I've already put a nice Ohio doe in the back of my s6 during ohio's bow season. Lol
#26
No problem. Good tip on the silicon, as I was a little put out about the cost of new spacers. Thanks.
#27
I just did my rears also. Very easy. Just need rosstech software and cable to set the parking brake then just two bolts and pop the old pads out then in with the new. Both sides took less then an hour.
#28
my rotors and pads are shipping this week. other than the "cross shaped" spring on top of the caliper, were there any other hardware pieces that you reused? I see other stainless steel spring like devices when I search for Audi S6 brake hardware. For instance, search for this.
CENTRIC 11733043 Disc Brake Hardware
Cheap insurance to replace all these parts.
#29
Nope, anything I replaced was noted in the write-up. In my mind, the only necessary parts to replace are the pads (and, if worn beyond spec, the rotor). In retrospect, even the sticky pads could be reused (as another poster did). Nothing else should wear.
#30
The numbers are similar: 117.33044 (front) & 117.33037 (rear)
