HOW-TO: Lowering AAS via VCDS
#21
Hello I tried to change the height according to the information. First problem I have 4 different values (right before 388, 394, front left, rear right and left rear 383 392 mm). Security code works but when I want to change the height (401.5 example) I get the message that "the computer seems Virgin of shop / importer and material numbers"
Have you ever had this message? Do you know these codes?
thank you very much
thank you very much
#23
It shouldnt because you arent reflashing the ECU as an entirety. If changing this one thing then that means any type of VAG mod would cause a flag. Anytime you mess with a computer you take the risk of doing something negative. Gotta pay to play.
#24
Hello, guys
NOT WORKING!!
i would appreciate your continues amazing support !! some how im stuck in getting the security access to proceed with keying the numbers.
please help where can i find my number?
NOT WORKING!!
#25
BTW, where are you located?
#28
seems that its also deletes the coding.
have to take it to a dealer unless theirs another way to fix it.
#29
I can confirm this works on my 2012 Audi A8.
I tried following a different write up which didn't include the deleting of the preset values. It kept giving the sequence error. Make sure you follow this guide step by step, worked first time for me.
You know if you've done it right if you go into adaptation and your 4 corners have no values in the boxes. Just put your wanted value in the 'new' box and click do it.
#30
Hi , did you get yours sorted "Mohammed Radwan"? I have the same issue on my 2011 A8 D4, after i mistakenly deleted all adaptations. I follow everything step by step but when i choose to Calibrate Level Control at the end it says Request Sequence Error. Any ideas on how to solve this?
