HOW-TO: Lowering AAS via VCDS
#41
A6 Allroad default values
Did some measurements to my A6 Allroad and seems like in front i have 10 mm difference between right & left
Do you know the default values of the initial setup ?
I did find on RossTech site Ross-Tech: VAG-COM: Suspension Level Control Calibration the values for the Audi A6 (4F) Allroad (PR-1BY): 388 mm (front) and 380 mm (rear) and put it on the C7 4G but now the car stands pretty high
I will put back the initial ones with front correction but I wonder if somebody knows the initial ride height values for A6 C7 Allroad
Best regards
Best regards
#42
Thank you for step by step instructions! Worked well , except I could not do any changes to previous values (Step 4) until I first did the "Delete calibration for level control"
Only did 10mm , I will see how it goes and if everything ok I may do another 2 to meet my initial goal of 12mm
#43
I know this post is been dead for a little bit but I just did this same procedure through my Autel 906S scanner successfully. Thanks for the info, I got a 2013 S8 D4, it looks and drives much more sportier thanks to this info, I didn't want to use the links and this worked out pefect. THANKS!
#45
#47
Sweet - thanks!
Going to try for sure. Probably a modest 10mm or so. I'll likely have the car re-aligned afterward too, since I've got 20k miles and haven't done an alignment.
I'll report back on how it goes.
#48
Reporting back as promised. Instructions were great and worked perfectly first try on my C7.5 2016 S6. Lowered 12mm against stored values. I may redo it later with real measurements when I'm feeling more OCD, but this'll do. Took a short drive and dynamic mode at this lower height definitely feels stiffer but not uncomfortable. More driving will yield more feedback - I'll be back to share that in the future.
Thanks for the instructions - made it very easy to do this modification.
09S5 (08-29-2021)
#50
Thread revival! This worked great. Got my car lowered 15mm and it looks awesome with the new wheels I put on! Had oddly different stock sizes which seemed normal from the posts, but I added 15mm to each and it looks pretty darn even!
