I'm Done with My 20inch on the S6!
#11
Questions: What pressure are you running on the 20's and how does it compare to each of door sticker and the various manual pressure ranges? Have you checked them since car was delivered?
Variously:
1. Nothing in this thread or the prior one seems to mention pressures. Critical in lower profiles. Don't assume dealer set them correctly, either new or following a service. Yes, they are supposed to. Yes, lots of posts that confirm often they don't.
2. If you still have the other original 20's on car and didn't fool with pressures, check them now. If I follow correctly, sounds like this is a new car. Thus, are you sure dealer aired them up correctly, esp. relative to any weather changes or car sitting pre-sale? If you find them mis set, need to have a discussion w/ dealer, though good luck trying to get them to own up to something in this arena.
3. Realize door sticker is the max load setting, while manual has a variety of pressures depending on part vs. full load, as well as the various tire/wheel size options. Given your experience so far, sounds like you want them on higher side anyway.
Variously:
#12
Variously:
Variously:
#14
Do check the Tire Rack...
They have a great array of choices an excellent prices.
Eric
#15
Hey Eric which company are you referring to ? thank you appreciate the response.
#17
Sorry - left off the title...
Wheels for 2016 Audi S6
I do my choosing on line, then call directly - I have been working lately with Chris
Good Luck
Eric
#18
Wheel weight
I notice that the weight of the listed aftermarket S6 wheels varies from about 24 to 34 lbs each. I understand that lighter weight wheels improve handling (unsprung weight issue) but how does weight affect durability? What do the OEM 19" and 20" wheels weigh? Is there any data? Incidentally, I have destroyed two 19" wheels/tires in potholes (raining and couldn't see them) and bent a couple more. My Allstate tire/wheel warranty has been great as they provide a new wheel and tire - no questions asked. It cost $1500 from the dealer in 2013.
Tire Rack
Good Luck
Eric
Good Luck
Eric
#19
Wheel weight is not directly related to strength...
The highest strength and often lightest in weight are the forged wheels (they are also the most expensive). The least expensive, and also the heaviest, are gravity cast. They can be a bit porous and may not always be the most strong. That is why a conversation with the tech at Tire Rack is so important. They know which ones are bending and coming back…
I hope that is helpful...
#20
