Lap timer and boost show in display
I have a 2013 S6 I have seen others that had a feature that shows lap time and boost in the display between gauges..... Can I turn that feature on in my S6.....if so,how do I do it?
VCDS. There is a huge list floating around on the forum that outlines all steps required to enable these features.
VCDS is one of the definitive diagnostic programs for VW/Audi Group cars. It's a Windows app.
Ross-Tech: Home
The software is a free download, but requires a proprietary cable to interface to your S6 (that also serves as the software license dongle for the app).
Ross-Tech Store: VCDS License with HEX-USB+CAN Unlimted VIN (All VAG)
It's pricy, but worth it if you intend to highly tweak and/or benchmark your car.
Alternatively, if all you really want is to enable the lap timer and a few of the other common "secret" features, and read trouble codes, the Carista mobile app + Bluetooth connector can do this for a lower price than VCDS.
Carista ? OBD2 vehicle diagnostics, customizations, coding & tools
I have both. They are good products.
Ross-Tech: Home
"So far we have the following:
- Disable amber corner lights
- Disable NAV & Phone warning messages while entering data at speed
- Disable Seatbelt Chime
- Enable Adaptive brake lights
- Enable Automatic Gear selection shown in DIS
- Enable Double Disarm Beep
- Enable Hidden menu in MMI
- Enable Import CDs to MMI's HD
- Enable Independent Fogs control with high beams
- Enable Lap Timer
- Enable Remote Operation windows&sunroof
- Enable TPMS
- Enable VIM on MMI
- Set Audi parking system - Switch OFF Speed
- Adjust LED Brightness
- Beep on lock
- Adjust bluetooth microphone sensitivity
- Enable Auxiliary ventilation
- Enable Drivers Memory Seat
- Increase radio play time after car is turned off
- Enable coming home/leaving home function DRL
- Tail lights on with front DRLs
- Change the Adaptive Cruise Control Preset distance
- Enable power trunk to close from key fob
- Disable start/stop
Equipment Required:
Laptop with Vag-Com software
Vag-Com Cable"
09S5 (04-03-2022)
escargot
Performance and Tuning
10
05-02-2004 09:07 PM
Bruck
12-11-2003 02:43 PM
Nachos
08-26-2002 02:22 PM
