Radio Presets keep getting deleted
2016 S6 Black metallic Premium Plus with Tech package
Somebody tell me that they're having the same problem and that I'm not crazy. I set up my radio presets and with no rhyme or reason or pattern, one or two of them get deleted. I have reassigned my presets - either partially or completely - about a dozen times. The same thing happened with the HD radio. I kept turning it OFF and it would automatically revert back to ON.
I brought it to the dealership for another reason and had the salesman look at it and he "reset" the radio but this didn't help.
Any insight greatly appreciated....
I experience this as well and find it very frustrating. I need to re-read the manual to see what I might be doing.
Chris JB
2016 S6 Prestige - Tornado Gray Metallic, Black Optic Package, Sports Package, Cold Weather Package, Rear Side Airbags, Layered Aluminum/Black Wood inlay
Chris JB
Not sure if 2014 differs from 2016, but noted same problem with disappearing and translocating pre-sets early on....also thought secondary to unintentional light touch, so since then have not used the touch pad, intentionally keep my hand away from the console and strictly use the steering wheel "wheel" to scroll through and select stations----have not had a problem since such time, except for one occasion when i accidentally dropped my guard, er hand, on the consul. Have thought about placing a plate of sorts over the touch pad, but will likely not get around to same. my two cents.
I noticed this early on and pointed it out to dealer, who was not helpful (the usual "could not replicate")
I gave up and never use the touchpad for presets. Only the scroll wheel.
May seem like a small bug but it renders a significant function useless.
Originally Posted by GolfGL
You could check to make sure you are using the same key fob? I believe the presets are one of the settings tied to the key in use.
