Rotor Options?
Rotor Options?
Anyone replace their front rotors with anything but OE yet? Not finding much of anything out there, even ECS appears to just sell just the OE rotors. Looking for a slotted/drilled set, also 2 pc setup if available.
Adam's Rotors
Haven't had to replace the rotors on my A6 yet, but intend to use Adam's Rotors when necessary. I used these on my S8 and was very happy with the appearance and performance, when paired with CarboTech pads. He has a number of combinations of slotted and drilled rotors to be made up according to your wishes.
Rears are more standard and you will probably find some aftermarket if desired.
Thanks for the info. Is definitely something a bit unique, wasn't expecting that. Suppose, given some time, more aftermarket solutions will appear. In the meantime, if you don't mind adding some unsprung mass to your corners, the beforementioned Adam's Rotors look to be top notch quality replacements.
Audi TT Selling 2012 OEM TT Front Grill
X-SoLjA
03-31-2016 07:04 AM
Dr944S2
03-28-2016 07:54 AM
alcoholicgab
03-21-2016 08:22 AM
