S6 Oil Change - How Frequent?
#21
low oil
I had my oil changed at 14k and i am just about to hit 19k. I just had the low oil light come on. "still safe to drive" but at the warning mark. seems quick to me, but no oil on the ground in the garage and no smoke.
will take it in to see what they say.
#22
Even though modern oil lubrication properties have greater advanced, cars with turbo engines do run hotter which increases the chance of deteriorating the oil's effectiveness faster---dependent on your driving style to be sure. I generally do 10k miles per year, and schedule oil changes at either 5k miles or every 6-months, whichever occurs first...on both N/A and especially turbo engines, despite the fact that I also have AudiCare. Even though I lease, my feeling is that if I want to buy my car at lease end I'm secure in the knowledge that I've done everything within reason to promote optimal engine component lifespan.
#23
When I purchased my first Audi (2001 2.7t A6, std trans) and saw the 10K oil change interval, my first reaction that it was Audi trying to save money as back then the first 50k of oil changes were free. But I went along with it and carefully changed the oil every 10K miles with synthetic. Today I still own the car - 235,000 miles, with original turbos, clutch, alternator, starter, etc. Other than timing belts no significant maintenance. It is still fast, and burns less than 1 qt in 10k miles. (In addition we have a 2015 S6, which means the old Audi no longer gets driven hard)
#24
and FWIW, and since syn-oil has been available, I change every 10k...Never experienced any motor failures of any type. Oil change intervals are a personal thing....whatever makes you feel good!!!
#25
Not sure I agree that turbo fed motors run hotter. if anything, turbo motors are lower compression and lower heat. If you have too much boost and not enough fuel to keep that 14.7 sweet spot and it starts to run lean that will increase motor temps.
I suppose being the Luddite that I am, I'm a bit more comfortable changing the oil and filter twice a year (every 5K miles or 6-months). I know if I had an S-variant car and drove it harder (more spirited, shall we say), I'd definitely stick to that schedule. Bottom line is I don't trust Audi's minimum recommended oil change maintenance schedule...just a personal preference that allows me to sleep a bit better I guess.
zub3qin
05-24-2011 12:41 AM
