S6 Turbocharger Oil Leak
#11
mine just had the same problem, im picking up the car later today. my service guy said would have cost $1200 out of pocket if there was no warranty. I have a year left on my lease and like the car, but don't trust keeping it out of warranty. not to mention, the fuel line problem left me stranded in san diego, im definitely going to return the s6 and try something new when the time comes.
#13
Hi - quick question for you. Did you smell anything before you saw the leak? I don't yet see a leak but have started smelling the slightest tinge of coolant when I pull the car hot into the garage. If I open the hood, I don't smell anything, and I don't see anything (nor are there any puddles on the garage floor).
#14
#15
Yes you have a leak. Call Audi in the morning. Get them on it ASAP. Problem is the parts took a few days to arrive. Good Luck.
#17
again
I smell coolant again. After the last repair (the second repair) the car had a full coolant chamber. I'm down to less than the lowest indicator on the tank with a hot or cold engine. I guess I'll take it in again.
#18
Repair? Audi put out a TSB last June to completely replace the lines and seals. Tell them you know about the TSB and they should have done the job correctly the first time.
#19
I sent the photo above to my service advisor and he showed it to the 4.0T expert on staff and they were able to confirm a turbo coolant leak and order the parts. I have an appointment for two days after I get back to town, and they'll need the car for two days. He said it's OK to drive in the meantime as long as I don't let the coolant get low, but I checked last night and it still looks full.
That would seriously **** me off.
This is more like it. We have the TSB number and I will not be satisfied unless a permanent repair is made. I also expect that the parts with corrosion on the outside (only on the side with the leak) will be replaced so I don't have problems down the road.
#20
