Steering End Stops Not Learned
Power Steering Assist seems to not be working.
Have this fault code:
Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H36 0010
Revision: 00001000 Serial number: 0010176758
Coding: 101000010000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS.rod
VCID: 3228DA01658C89AE9B-8066
1 Fault Found:
5258753 - Steering End Stops Not Learned
C10AC F0 [137] - Unknown Error Elaboration
MIL ON - Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 98
Mileage: 33741 km
Date: 2015.09.21
Time: 20:46:10
Looks like the steering wheel limits need to be set? Is this something I can do with VCDS, or does the dealer have to do it?
ROD: EV_RCEPS.rod
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 98
Mileage: 33741 km
Date: 2015.09.21
Time: 20:46:10
LOL Touche. I would take it to the dealer then, should be quick warranty fix.
If it was me, Id probably take my VAG and try to figure it out kind of how you reset the height when lowering the car and then resaving it. That being said I would also probably end up screwing up my car even worse.
So yeah, take it to the dealer.
N'Syncro
33
02-16-2020 03:12 PM
the_duke
09-10-2015 09:02 AM
Zumkopf
09-10-2015 05:23 AM
Zumkopf
09-04-2015 03:06 PM
