Suspension settings for winter driving
So I just popped a bubble into the sidewall of my one month old Dunlop Winter Sport after smacking into a decent sized pothole. I am no air suspension expert, so my question is this:
Is the suspension more compliant at soaking up hits like this if it is raised or in comfort mode? I was in dynamic mode when this happened.
Thanks.
Thanks.
More wheel travel means the suspension can help absorb a jolt that might otherwise bend your wheel. I drive in raised mode in winter almost all the time. Better in terms of clearing ruts, too.
In the S6, the dynamic mode is the firmest setting and lowest setting as well. Comfort is the softest setting and highest and will allow the most wheel travel so the rim doesn't absorb as much of the impact.
Comfort setting
Comfort is definitely softer than Dynamic. I frequently keep it there and just nudge the shift into S when I feel the need to accelerate. I am not sure that will help much with pothole damage to tires. I blew one of my OEM summer tires on a pothole.
if you hit something hard enough to bubble your tire or bend your wheel, i don't think it matters what setting you choose, its going to bend or bubble regardless.
Sorry, that doesn't even pass the common sense test. If you jump off a six foot wall, are you better off bending your legs when you land? Of course it won't matter what you do if you jump off a ten-story building, but then not every pothole is the vehicular equivalent of a ten-story building.
Casablanca Avant
04-25-2008 07:07 AM
Will a tighter suspension like the MTM suspension/shock setup screw with winter driving performance?
S4ORCE1
01-28-2002 01:29 PM
