S6 (C7 Platform) Discussion Discussion forum for the C7 Audi S6 produced from 2012 - 2017
Suspension settings for winter driving
Old 01-26-2014, 09:15 AM
Vijay's Avatar
Default Suspension settings for winter driving
So I just popped a bubble into the sidewall of my one month old Dunlop Winter Sport after smacking into a decent sized pothole. I am no air suspension expert, so my question is this:
Is the suspension more compliant at soaking up hits like this if it is raised or in comfort mode? I was in dynamic mode when this happened.
Thanks.
Old 01-26-2014, 10:37 AM
tenspeed's Avatar
The raised position will allow for more wheel travel.
Old 01-26-2014, 11:47 AM
60614allroad's Avatar
True, but in my experience (on my RS7) the ride is no softer in the raised position. On my Allroad, the ride is actually firmer when raised.
Old 01-26-2014, 12:24 PM
DeerHunter's Avatar
More wheel travel means the suspension can help absorb a jolt that might otherwise bend your wheel. I drive in raised mode in winter almost all the time. Better in terms of clearing ruts, too.
Old 01-26-2014, 01:40 PM
gatorguy7's Avatar
In the S6, the dynamic mode is the firmest setting and lowest setting as well. Comfort is the softest setting and highest and will allow the most wheel travel so the rim doesn't absorb as much of the impact.
Old 01-26-2014, 08:24 PM
DD1546's Avatar
Default Comfort setting
Comfort is definitely softer than Dynamic. I frequently keep it there and just nudge the shift into S when I feel the need to accelerate. I am not sure that will help much with pothole damage to tires. I blew one of my OEM summer tires on a pothole.
Old 01-27-2014, 05:06 AM
HyperS4's Avatar
Comfort and Auto are at the same height setting. Comfort is however softer than Auto.
Old 01-28-2014, 12:12 PM
mikec7s6's Avatar
if you hit something hard enough to bubble your tire or bend your wheel, i don't think it matters what setting you choose, its going to bend or bubble regardless.
Old 01-28-2014, 12:51 PM
DeerHunter's Avatar
Sorry, that doesn't even pass the common sense test. If you jump off a six foot wall, are you better off bending your legs when you land? Of course it won't matter what you do if you jump off a ten-story building, but then not every pothole is the vehicular equivalent of a ten-story building.
diehlryan
12
05-27-2008 01:18 AM
Casablanca Avant
04-25-2008 07:07 AM
kquast
01-16-2006 04:56 AM
ChewyA4
9
08-05-2003 01:21 PM
Quick Reply: Suspension settings for winter driving
