S6 (C7 Platform) Discussion Discussion forum for the C7 Audi S6 produced from 2012 - 2017
VMR 19" or 20" on S6
Old 09-20-2014, 02:31 AM
skenn1977's Avatar
Default VMR 19" or 20" on S6
A lot of good threads and pics on VMR wheels with the '13/'14 S6. Looking at the VMR v708 (RS4) rim for winter use. I've seen threads/pics of the 20" and sounds like a great fit (thanks Vijay). Does anyone know if the 19" will fit? I'm getting conflicting information from different folks. Will run a stock 255/40R19 wheel, just not sure if it will fit over the brakes. Assume these are hub centric 66.1 and the audi center caps will fit?
Old 09-20-2014, 01:14 PM
Vijay's Avatar
I really really doubt the 19" will clear the calipers circumferentially. The geometry of the VMR 708 is such that the inner barrel is somewhat small for a 20" wheel. There is actually reduced clearance even in 20" for the calipers compared to the stock wheels.
If you look at the pic below, you will see how the inner barrel is stepped up. You can also see how close the inner barrel is to the caliper. No way 19" will clear.
Old 09-21-2014, 04:44 AM
skenn1977's Avatar
Thanks Vijay. I'm assuming you didn't have to use any spacers or hub rings?
Old 09-21-2014, 10:19 AM
Vijay's Avatar
No spacers or rings needed. Fitment is really perfect in 20".
Old 09-22-2014, 12:24 PM
skenn1977's Avatar
Any recommendations on where to buy VMR wheels? Directly from VMR or does anyone have a good source they'd recommend?
Vijay -- did your Audi OEM center caps fit the 20's?
Old 09-23-2014, 03:51 AM
Vijay's Avatar
I bought directly from VMR. The Audi center caps do fit (look at pic) but it is a tight fit. Be careful putting them in.
Old 10-12-2014, 01:04 PM
skenn1977's Avatar
Vijay -- were you able to use the OEM lug bolts with the 20" VMR 708s? I'm assuming I don't need to do with the TPMS other than recalibrate from the MMI menu.
Old 10-13-2014, 01:49 AM
Vijay's Avatar
Yes, you can use original lug bolts. Nothing to do with TPMS other than recalibrate through the MMI
Blaster an
10-15-2015 01:00 PM
VMRWheels
20
05-18-2009 10:40 AM
VMRWheels
12-27-2008 08:04 PM
VMRWheels
11
12-04-2008 09:06 AM
VMRWheels
Wheels & Tires Discussion
09-25-2008 06:53 PM
Quick Reply: VMR 19" or 20" on S6
