S7 Discussion forum for the Audi S7
RS7 grill on a S7...?
Old 02-10-2016, 12:53 PM
Adam Gruen's Avatar
Default RS7 grill on a S7...?
Has anyone put an RS7 grill on a S7? Is it just plug & play? and where's a good place to get one? Also, what did the mod cost (Parts & labor)?
Thanks in advance!
Old 02-11-2016, 03:02 PM
RAF_S7
jkwelsh's Avatar
It depends on whether your running a facelift A7 or not.
On the pre-facelift S7/RS7 you could swap over without too many issues (cut off a few tabs to make it fit)
On the facelift (2016) S7/RS7 the grills have very different mounting points, but its still doable if you modify the RS7 grill (there is a lot more cutting to make it fit the S7)
Here is a link to a guide (for the pre-facelift, the 2016 is not much different)
https://www.audiworld.com/forums/a7-...moval-2874257/
You can search the forum for loads of other posts on the subject.
Ive not seen any aftermarket grills for the 2016MY yet, so you only have OEM available for now - and they are way expensive....
There are a few aftermarket options for the pre-facelift S7, so a lot cheaper to purchase.
09S5 (03-23-2021)
Old 02-21-2016, 01:31 PM
Chris Powers's Avatar
Lots of conversation about the grills here, but can anyone post an actual link to an RS7 grill that accommodates the front camera/park assist...i.e. eBay? A grill you actually have purchased and have on your car please.
Thanks for the help!
Old 03-04-2016, 05:37 AM
08A6's Avatar
Here's a pic of mine.. The grille comes with the Audi ring backing to accomodate the Night Vision camera, and can accept your stock silver rings. It comes with gloss black rings. Aesthetically, it's the closest i have seen to the OEM RS7 grille
Got it from Dubstop in Mass. He's on ebay..
09S5 (03-23-2021)
Old 03-12-2016, 05:32 AM
JoeCaMotto's Avatar
Looks good👍
Old 03-20-2016, 06:55 AM
dent2003's Avatar
How hard was the install? Did you find directions on removing/installing the bumper cover?
Old 03-21-2016, 11:11 AM
08A6's Avatar
i had my Audi tech install it, and he did remove the bumper cover..and sprayed some black paint on the silver crash bar behind the grille to camouflage it.
Old 05-04-2016, 10:01 AM
RAF_S7
jkwelsh's Avatar
OEM (Facelift) RS7 grill installed onto my S7.
Did the install myself, and it was a total B!tch....
Looks great though
Facelift RS7 grill fitted to a 2016 S7<br/>
09S5 (03-23-2021)
Old 04-05-2017, 01:35 PM
jimmymp5225's Avatar
Default RS7 grill on 2012 A7
I bought mine from ebay for $180 and paid a guy $150 to install. Took the whole bumper out and spray painted crash bar with Rust olueum Black gloss spray paint (primer+paint).
Also took it off that plastic gray part which is not needed.
09S5 (03-23-2021)
Old 04-10-2017, 10:29 AM
davelong9050's Avatar
Thanks in advance!
Lot's on Audizine. Check this out.
How To Replace 2016 S7 Facelift Stock Grill With RS7 Honeycomb Grill
Quick Reply: RS7 grill on a S7...?
