S7 gas door won't release
Any others with this problem. It happened to me a few times now. I pull panel off in rear and pull the emergency pull and it will operate normal for several weeks Then it does it again. What gives? Thx. Joe
Just sounds like it's on its way out.
I had the stuck gas door on my previous C7 A6 and i couldn't even open it with the emergency pull. It's a known failure item. I would suggest addressing the failing lock mechanism so you don't end up stuck with little gas and no way to open it!
I've had the same issue intermittently. I lock the doors, give a push on the filler door, then unlock again and I'm able to open it. Have a similar issue with the cup holder cover. Push on the front edge and that seems to unstick the back to be able to open it again...
I was having similar issues on my 2013 S7 and the dealership was able to correct. Would get gas in NJ where they pump for you. So embarrasing to have to exit the car and contiuoisly press on the gas door with no success. Well I guess I'll come back another time!
Phil
09-18-2003 08:57 AM
10MPTME
19
01-04-2002 07:52 AM
