Misfuel adapter
Old 11-24-2015, 05:18 PM
meob's Avatar
Default Misfuel adapter
Good day first post for me!! Has anyone removed the stupid misfuel adapter? Theres no "proper" nozzles in my town and I'm getting sick of dribbling fuel through the nozzle adapter. Im now hauling fuel in cans to fill a drum to use a rotary hand pump as its slightly faster and cleaner. Worst thing is the wife can't get fuel if I'm out of town.Some one other than me must hate this enough to remove it. and its 2000km drive to the dealer. Hoping some one knows how it comes out. I don't want to just start ripping at it.
Thanks
Old 11-28-2015, 07:12 AM
meob's Avatar
Some one must have played with this.
Old 11-29-2015, 04:27 AM
J. Patterson's Avatar
Default Do you have one of these?
Thanks
I have never used one but it should work.
http:// http://www.ebay.com/itm/like...chn=ps&lpid=82
" 2000 km from dealer". WOW Good luck!
Old 11-29-2015, 12:12 PM
MelsQ7's Avatar
Default Check if it's a recall issue
Thanks
I WAS SEARCHING Q7 RECALLS AND I THINK THIS IS ONE, CHECK.
Old 11-30-2015, 07:25 PM
meob's Avatar
Can't find any recalls. I just want the contraption in the filler neck gone so it's a straight pipe like my truck.
Old 12-01-2015, 05:02 AM
Edd W's Avatar
Amazon.com: TDI Diesel Fuel Nozzle Adapter: Automotive Amazon.com: TDI Diesel Fuel Nozzle Adapter: Automotive
Old 12-01-2015, 06:23 AM
meob's Avatar
Using one like that now it's a pain in the ***. I just want to pull up to the pump and stick a nozzle in no mater what the size (everything we own is diesel except the ATV and snowmobiles so no I'm not going to put gas in the rig lol) So I want the missfuel contraption taken out of the filler neck. There's lots about the VW ones but there diffrent. I don't want to go ripping into it and loosing little plastic pieces into the tank any one have a shop manual that shows removal or install?
Old 03-26-2017, 10:06 PM
White-Tee's Avatar
I removed mine last night from my '15 A3 TDi. Looking at the nozzle with the cap removed, you should see two holes, one on each side of the outer ring at the 3 and 9 o'clock position. Using a set of lock-ring pliers, insert the tips into each hole of the outer ring and turn the ring counter clockwise until it stops (about 3/8"). The outer ring can be pulled out with either the lock ring pliers or a set of needle nose pliers. Lastly, remove the misfueling adapter insert carefully with needle nose pliers or wire from a metal coat hanger. You can now fuel unimpeded.
Old 03-27-2017, 05:48 AM
Greystoke's Avatar
Nice of you to post the answer but I doubt he will be back to look at it a year and a half later.
Grey
Old 07-29-2018, 01:23 PM
Paul47's Avatar
Thanks, that worked for me. The insert wouldn't come out until I pulled pretty hard.
trg
14
01-02-2020 10:33 AM
sbickett
A7
17
05-22-2017 09:43 AM
Mason Williams
06-16-2014 01:03 PM
MikTip
10
03-14-2006 12:55 AM
boogs
11-05-2005 12:29 PM
Quick Reply: Misfuel adapter
