ABS module removal
ABS module removal
Can the module be removed without disconnecting the ABS brake lines, etc
If I remove the module, can I cover the ABS with a plastic bag and drive till repaired unit come back?
You can remove it without disconnecting any brake lines. Probably you can drive without it, but I wouldn't suggest that. I am also suspicious about repairing A8 module.
AudiWorld Wiseguy
The ABS/ESP module (hydraulic modulator) is a Bosch 5.7 unit that is used on the contemporary A4, and literally millions of other vehicles worldwide. Obviously it's programmed specifically per vehicle type but there is nothing special about it so repair of it should be routine for any module repair shop.
The only thing of any note is for cars with adaptive cruise, they use a slightly different modulator, but it's still a Bosch 5.7 at its core.
Although in your case you should really double/triple check the wiring loom as there is still likely a short in it, causing the residual errors. You also want to make sure it's short free as plugging a repaired abs module back into it may damage it again, putting you back at square one.
I did just that, when I sent my bosch 8.0 abs module out for repair. I covered both the abs pump face & the cable end, separately & carefully. The car was functional but, boy, were there a lot of screwie indications in the instruments. It made me glad to get the module back & installed.
Hey guys where exactly is the ABS module and its wiring located?
Every day I have been having the Parking-Brake and Traction Control Error after 5-10mins of driving and now as winter is here I should definitely do something about it ahaha.
I am 90% convinced that the module is fine, its the wiring that has shorted, I just don't know where the wiring/abs module is located.
DONT drive A8 without ABS Computer you can destroy the Air Suspension, many things rely on that module to work right, Air Suspension, Navigation, Adaptive Lights, Parking Brakes, SRS Airbags, and the list goes on, repairing is a waste if time just get a used or new on then recode it, the problem with A8 ABS module is that is sits close the the exhaust and the heat from engine over time cause bad solder and or components, putting a heat deflector around it will save it....
I'm convinced it is the wiring causing this hassle (many car wash incidents). I saw a video for an A6 C5 ABS module removal on CheapABS so thanks to you and that video I now at least know where the module is located. I was just wondering though the wiring for the module which is likely wrecked, will it have to be accessed via the wheel wel?
Hey Mishar, thanks for the reply. I had the Audi Stealership run scans on it using the VCDS and nothing came up regarding the ABS module other than a front right abs sensor which I had them replace.
you can do a continuity test between plug and abs harness but i dont remember the pins for the right sensor can wait till tomorrow and Ill check my laptop is at the shop.....
