Telematics Discussion
MMI 2g Bluetooth retrofit - hit a brick wall
Old 12-03-2016, 11:46 PM
Beena's Avatar
Default MMI 2g Bluetooth retrofit - hit a brick wall
I'm going through a retrofit of an oem bluetooth unit. Its all fitted in but I'm getting the 'telephone not connected' message and am not seeing it from my phone when scanning for bt devices.
I've activated it in the Can Gateway module list and changed the settings in Channels 133, 134 etc of Control Module 77 as per instructions on forums.
When entering the service menu, there is a new line in the right place (0x0103) but no device name when looking at the MOST list. Clicking on that gives me the software version (0950), part number (....336k) and the date, but no devicename, or hw details.
So there must be communication.
I thought a software upgrade would fix things but no such luck. Running disc 2 only takes about 4 minutes for the 'programming flash' bit, then it tells me that the update was not ok and it is still running 0950. There are a few messages about unlock no 1 please ( or words to that effect) but they fly past before i can scroll down to read them.
I thought running disc 1 could assist as I read somewherethat it can address incompatible sw/fw issues, but I can't select anything to run as everything is up to date.
Super confused, so any suggestions would be welcomed.
Old 12-04-2016, 12:10 AM
Beena's Avatar
Don't know if this is useful in this case but ....
Car: Audi A4
Year: 2009
Engine: CDHB
Mileage: 112260 KM
01 Engine Control Module 1
System description: 1.8l R4/4V TF
Software number: 8K1907115J
Software version: 0001
Hardware number: 8K1907115
Hardware version: H07
ODX name: EV_ECM18TFS8K1907115J
ODX version: A01002
Long coding: 0104000C02070020
Trouble codes:
No trouble codes found
02 Transmission Control Module
System description: 0AW 18TFSIRdW
Software number: 8K0927155T
Software version: 0007
Hardware number: 0AW927156H
Hardware version: H03
Serial number: 0000000312
ODX name: EV_TCMVL381
ODX version: A01015
Long coding: 000001
Trouble codes:
03 Brakes 1
System description: ESP8 front
Software number: 8K0907379AA
Software version: 0060
Hardware number: 8K0907379AA
Hardware version: H04
Serial number: --------------
Long coding: 050500
Trouble codes:
04 Steering Angle Sender
05 Kessy
System description: BCM2 1.1
Software number: 8K0907064F
Software version: 0134
Hardware number: 8K0907064F
Hardware version: H70
Long coding: 011100
Subsystems:
System description: FBSAUDIB8 IDG
Software number: 8T0959754C
Hardware version: H37
Serial number: 0508000033989021
System description: ELVAUDIB8
Software number: 8K0905852D
Software version: 0041
Hardware version: H36
Serial number: 0208000037683010
Trouble codes:
07 Display Control Unit
System description: Interfacebox H43
Software version: 5570
Hardware number: 8T0035730
Serial number: 331LV067504576
Coding: 0000302
Subsystems:
System description: E0380 BedienteilH08
Software number: 8T0919609B
Software version: 0100
Trouble codes:
03157 - Function restriction due to communication interruption
static
08 Air Conditioning
System description: KLIMA 1 ZONE
Software number: 8T2820043R
Software version: 0140
Hardware number: 8T2820043R
Hardware version: H06
Serial number: 0131.07.080865
Long coding: 64046000
Trouble codes:
09 Central Electrics
System description: BCM1 1.0
Software number: 8K0907063D
Software version: 0253
Hardware number: 8K0907063D
Hardware version: H22
Serial number: 00000000201216
Long coding: 260010110030AF010000000300001D0D4F1D43080001010100 0000
Subsystems:
System description: WWS 210708
Software number: 8K2955119A
Software version: 0070
Hardware version: H05
Serial number: SWFBIE 0000194
Long coding: 00FD11
System description: RLS
Software number: 8K0955559
Software version: 0003
Serial number: 10215105
Long coding: 025028
System description: E1 - LDS
Software number: 8K0941531G
Serial number: 00000000000608081624
Trouble codes:
0E Media Player Position 1
System description: MP3-Changer H44
Software version: 0390
Hardware number: 8T2035110C
Serial number: AUZ5ZBH8522718
Trouble codes:
15 Airbag
System description: AirbagVW-AU10
Software number: 8K0959655B
Software version: 0410
Hardware number: 8K0959655B
Hardware version: H26
Serial number: 0038JD18A1S5
ODX name: EV_AirbaECUVWAUDI010
ODX version: A02007
Long coding: 30373434363030303030554A3052384B3053
Trouble codes:
16 Steering Column Electronics
System description: Lenks.Modul
Software number: 8K0953568D
Software version: 0013
Hardware number: 8K0953568D
Hardware version: H12
Serial number: 90315HG90002C
Long coding: 000002
Trouble codes:
17 Dash Board
System description: KOMBIINSTR.
Software number: 8K0920930A
Software version: 0224
Hardware number: 8K0920930A
Hardware version: H16
Serial number: 9DZ547C88
Long coding: 2F0F08000200000C010000
Trouble codes:
19 Gateway
System description: GW-BEM 4CAN-M
Software number: 8T0907468K
Software version: 0092
Hardware number: 8T0907468K
Hardware version: H09
Serial number: 4200E0872584A2
Long coding: 000303
Subsystems:
System description: J367-BDM
Software number: 8K0915181B
Software version: 0150
Serial number: 1803502D260708
Trouble codes:
02077 - Media Player, Position 2 No signal/communication
static
37 Navigation
System description: MNS ECE H51
Software version: 1060
Hardware number: 4E0910888P
Serial number: 364EV087792701
Trouble codes:
42 Door Electronics Driver Side
System description: TSG FA
Software number: 8K0959793B
Software version: 0170
Hardware number: 8K0959793
Hardware version: H10
Serial number: 0000007538983
Long coding: 011C02205001410001
Trouble codes:
46 Central Module Comfort System
Serial number: 0112922700
Long coding: 0100062200390080033001
Trouble codes:
47 Sound System
System description: DSP STD
Software number: 8T0035223AG
Software version: 0310
Hardware number: 8T0035223G
Hardware version: H08
Long coding: 010201
Trouble codes:
00418 - Right front DSP mid-bass speaker Open circuit
Intermittent
52 Door Electronics Passenger Side
System description: TSG BF
Software number: 8K0959792B
Hardware number: 8K0959792
Serial number: 0000007544795
Long coding: 011C02205C01410001
Trouble codes:
02115 - Lock unit for central locking Implausible signal
static
53 Parking Brake
System description: EPB Audi B8
Software number: 8K0907801E
Hardware number: 8K0907801E
Serial number: 10000000078764
Trouble codes:
55 Headlight Regulation
System description: Dynamische LWR H01
Software version: 0030
Hardware number: 8K0907357B
Coding: 0000004
Trouble codes:
56 Radio
System description: TUNER EU/US/RDW H42
Software version: 0630
Hardware number: 4E0910541T
Serial number: 357CV097524950
Coding: 0000001
Trouble codes:
57 TV Tuner
System description: R78 DTV-JP
Hardware number: 4F0919148A
Serial number: 79300600184702
Coding: 0000016
Trouble codes:
03393 - Supply voltage for card reader Open circuit/short circuit to B+
static
62 Door Electronics Rear Left
System description: TSG HL
Software number: 8K0959795
Hardware number: 8K0959795
Serial number: 0000007587846
Long coding: 010C02204001210001
Trouble codes:
72 Door Electronics Rear Right
System description: TSG HR
Software number: 8K0959794
Serial number: 0000007560372
Trouble codes:
static
77 Telephone
Software version: 0950
Hardware number: 4E0910336K
Trouble codes:
