ABC V6 60-2 trigger wheel
Hi to all i got a Audi 2.6 v6 ABC got it with no ecu wiring all wrong so i want to put a after market ecu with a 60-2 crank trigger but my problem is the tdc part it should be at no3 on top so do not know if i can line my wheel on that tdc or should i do it at no1 or where should i check my timing from no3 or no1 with the timing light please help thanx in advance
Gilly..that is a tough question as you are going where no man has gone before..
My opinion..it does not matter if TDC is #3 or #1 as long as the firing order is correct. #3 becomes #1.
Thanx for the reply and on top of that it is a open source ecu called speeduino http://speeduino.com/wiki/index.php/Speeduino haha
