Audi Q5 2009 tfsi 2.0 211 hp CDNC (B8) ECM TCM firmware updates
My Audi Q5 2009 TFSi 2.0 211hp RHD CDNC (B8 valve lift) checking with vagcom the ecu tcm control modules and comparing with flash files database (which I downloaded from the internet):
ECU: 8R0 907 115 A 004 database gives new firmware 007
TCM: 8R0 927 156 AB 010 database gives new firrmware 011
Should I perform the firmware update?? Audi service said they can force the updates but it will be my responsibility. They cannot find tpi's or tsbs to tell me what they fix.
Can anyone advice of the service bulletin or/and SVM number??
Thanks
Thanks
Forgot to mention that it comes with 7-speed s-tronic. Cheers.
I had to enter Erwin in order to get this information.
1. ECM update was undertaken by Audi using TPI 2024604/28. The engine has improved dramatically. New VAG COM after update reads
Address 01: Engine (CL0MA-CDNC) Labels: 06H-907-115-CAB.clb
Part No SW: 8R0 907 115 R HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0002
Revision: E1H14---
Before the update it was:
Part No SW: 8R0 907 115 A HW: 8K2 907 115 D
Component: 2.0l R4/4V TF H14 0004
Revision: E1H14---
I had to clean my DTCs twice after the firmware update.
I noticed that there are 2 engine options to choose from with Vag Com.
0C Euro 5
0D Euro 6
Does anyone know if I choose Euro6 compliance, what the effects will be???
2. The only TPI I found on relevant to my transmission was TPI 2027286/9. (10 Oct 2016)
So it is proposing that latest firmware is 10 or greater.
Checking the firmware database there is an 11, so maybe using the same SVM number an upgrade will be given from 10 (my firmware) to 11.
My information.
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8R0 927 156 AB HW: 0B5 927 156 E
Component: 0B5 20TFSIRdW H04 0010
Revision: E1H14---
Revision: E1H14---
0C Euro 5
0D Euro 6
Old part number of gearbox software
Old part number of gearbox hardware
SW version:
New part number of gearbox software
New part number of gearbox hardware
SW version:
8R0927156AB
0B5927156E
8R0927156AB
0B5927156E
≥ 10
My information.
kahilmohamed
08-20-2018 07:38 AM
arjun90
04-18-2015 06:27 PM
Mat Indukts Lambos
VAG-COM Discussion
10
03-17-2006 08:30 PM
look@thatScar-Go
10-17-2003 02:19 PM
