Any indicator of mode in Drive Select?
When one changes the drive select mode from say Dynamic to Comfort, does the setting you're in show up anywhere? When I change mode, there is no indicator that the mode is actually changing. Am I missing something? Thanks. Regards. Ned.
If I remember correctly, the 6, 7 and 8 models don't have a Drive Select button on the middle console, so the current selected mode only shows up in the MMI under the Car menu. The highlighted mode is the current mode. On cars with a dedicated Drive Select button, the current mode shows up in the DIS if the button is pressed once and then as you cycle through the modes it shows the new mode in the DIS.
Civuck
Audi A3 / S3 / RS 3 MKII
15
12-09-2016 03:06 PM
