Replacing B & O door speaker
Old 02-05-2017, 03:03 PM
BASARAB's Avatar
Default Replacing B & O door speaker
Speaker crackles a bit and I would like to replace it. Seems like Audi sells just the whole assembly (two door speakers together), but I need to replace just the lower one.
Has anybody done that? Wonder if it would be possible to get that speaker from a place other than Audi
Old 02-05-2017, 03:38 PM
richard-tx's Avatar
WIth a few rare exceptions, most speakers are originally sourced through Seas Speaker. SEAS: The Art Of Sound Perfection
The problem is finding the correct one. If Seas does not make it, then you will have to source one from a junkyard/recycler.
Old 02-05-2017, 03:46 PM
BASARAB's Avatar
Its pretty much impossible to find a used one. Found one on Ebay for $200, but since new one is $360, dont want to risk it fail again. Thanks, will check with Seas
Old 02-15-2017, 01:35 PM
Jehu8's Avatar
I believe you are looking for this, if its the front door.
Old 02-15-2017, 01:58 PM
BASARAB's Avatar
thank you! So it's just a bass woofer? I thought it's a full range speaker
Do you know if it's 4ohm or 8ohm?
Old 02-17-2017, 06:39 PM
BASARAB's Avatar
I was pretty skeptical about $20 speakers being good and googled those Silver Flute woofers, people on different forums seem to be very pleased with them. I am gonna give them a try, ordered both 4ohm and 8ohm version to try out, since nobody knows what OHM do stock speakers have...
Worth the try before dropping almost $400 on a speaker from Audi dealer
Old 02-26-2017, 09:20 PM
BASARAB's Avatar
Received the speakers (used 4ohm one after measuring the stock) and it was the right size, but had to drill mounting holes a bit for better fitment.
Unfortunately, this speaker distorts and since stock B & O amp pumps 125w per channel, I assume I just need a better speaker.
After lots of researching the only speaker, which appear to fit, is Morel MW-144 4ohm version. It has 150w RMS, so hopefully it will be fine.
Believe it or not, the only other available 5 1/2 4 ohm woofer with over 100w power is https://www.madisoundspeakerstore.co...idrange-4-ohm/
apparently its a very rare size
P.S. The damage on the stock speaker is weird, I doubt it could have blowned up by itself like that
Old 02-27-2017, 04:16 AM
richard-tx's Avatar
What has failed is the speaker surround. This is caused by age plus environment. Very common problem. There are companies that will replace the surround for a modest fee but for something that small you might have to search.
I do not believe that excessive power damaged the speaker.
Old 02-27-2017, 05:00 AM
richard-tx's Avatar
I would also contact Simply Speakers as they may have a surround repair kit.
Here is one of their products.
Amazon Amazon
You may have to give them the surround OD.
Another source for drivers is Vifa/Typhany. Scanspeak and Vifa are also well known makers.
http://www.tymphany.com/
Old 02-27-2017, 05:29 AM
Aceler8's Avatar
I would just unplug the speaker. Bass is omnidirectional so I doubt you will hear any difference or loose bass. Plus, i'm sure there are subwoofer(s) in your system so you will not lose much if anything.
Trying to blend in a different type of speaker will make sound worse.
Quick Reply: Replacing B & O door speaker
