Start/Stop System with manual transmission?
I've had by B9 A4 with manual transmission for 2 weeks now and I'm getting more familiar with what all the buttons do. I'm surprised to notice that I actually do have the Start/Stop disable button on the center console. I didn't think that a manual transmission car would even have the start/stop feature. I haven't notice the engine stop with the car, except possibly once (not sure, just felt some hesitation when trying to move).
Has anyone with a manual transmission confirmed whether it has start/stop or not?
Why would you think it didn't have start/stop? In my experience it works a lot better with a manual transmission actually. The way it usually works with a manual transmission is that it only stops the engine if you put the transmission in neutral and take your foot off the clutch pedal. Essentially what you should be doing when coming to a stop at a light to avoid unnecessary wear of the clutch throw out bearing, and then as soon as you push the clutch back in, the engine restarts. The latter is what makes it smoother. The engine has plenty of time to restart while you push in the clutch, put the transmission in gear and then let out the clutch. With an automatic transmission it gets a bit rough, because the engine needs to restart while you change from the brake pedal to the throttle, which is a much shorter window and if you do it too quickly the car ends up jerking off the line.
I did try it today and it worked as you said, wouldn't have even known about it otherwise. Thanks!
Wait! You have a 6MT? Have you provided a review yet here? I've been waiting to hear about the 6MT B9. If you've done it somewhere else on this forum, please let me know!
I'm still trying to find one to test drive. Wish me luck...
I've never done that coming to a light, I just sit there in first gear with the clutch depressed. Hadn't heard you're supposed to do otherwise. Never had a problem with it wearing things down and I drove my last car 220k miles without replacing the clutch.
I recall I had to put it into neutral to let my left leg rest when I was driving stick. Clutch paddle was way harder to push than brake or gas paddle at that time. That's about 10 years ago though. Are the clutch paddles electronic instead of mechanical now a days?
You have a very strong left foot/leg to hold the clutch paddle at lights. lol
I've been doing it that way since my first car which was a '78 Honda Civic 1200cc with manual transmission and manual choke. Never really bothered me much.
As a general review I'm also starting to notice a few things, like how the lousy navigation routing compared to what Google would do causes the built in nav to be less useful which means the virtual cockpit is a bit less interesting. If you've got the adaptive cruise control active, the use navigation for ACC setting turned on (which was supposed to be a significant feature), and you're navigating, then the lousy route guidance can cause the car to suddenly start slowing down for a turn you have no intention of making - that quite surprised me on my way home from work until I figured out what was going on.
I also think that maybe not all of the voice commands mentioned in the owners manual are actually known by the car. I could be wrong, but the manual says in navigation you can say "calculate alternative routes", but I don't think I saw that listed in the car when I asked for help in the navigation screen and I was planning to try to use that.
My A4 turns off all of the time (stoplight in neutral, no foot on the clutch), but it's always on by the time I roll off of the clutch in first gear. I will say, I turn the feature off when I'm driving through downtown because it can be annoying in traffic.
Suncake119
11
11-05-2009 12:26 PM
How Bizarre
03-08-2006 11:00 AM
