Newish C6 V6 diesel owner hoping to solve some issues
HI guys
I bought a c6 avant a few weeks ago and it feels like it's struggling to start first thing in the morning and sometimes idles erratically for a few seconds afterward.
I've scanned it today and its thrown up a fair few errors, I wonder if you might take a look through the scan and help me to help myself.
Thanks in advance.
Sunday,19,March,2017,17:23:12:62939
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WAUZZZ4F46N006392 License Plate:
Mileage: 174500km-108429mi Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 55
56 61 62 72 76 77
VIN: WAUZZZ4F46N006392 Mileage: 174500km/108429miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4F0 910 401 A HW: 4F0 907 401 B
Component: 3.0L V6TDI G000AG 0020
Revision: --H01--- Serial number:
Coding: 0011372
Shop #: WSC 66565 257 00032
VCID: 1A3B34E3D56A62CE7A7-804F
2 Faults Found:
005715 - Please check DTC Memory of ABS Controller
P1653 - 002 - - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 173991 km
Time Indication: 0
Date: 2017.03.06
Time: 10:42:40
Freeze Frame:
RPM: 1008 /min
Torque: 159.9 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.55 V
Bin. Bits: 00101100
Torque: 280.8 Nm
006275 - Park/Neutral Switch
P1883 - 001 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 174137 km
Time Indication: 0
Date: 2017.03.09
Time: 15:04:18
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.24 V
Bin. Bits: 00101100
Torque: 89.7 Nm
Readiness: 0 0 0 0 0
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4F1 910 156 B HW: 09L 927 156 A
Component: AG6 09L 3.0lTDI RdW 0030
Revision: --H01--- Serial number: 0098173
Coding: 0000001
Shop #: WSC 02335 785 00200
VCID: 23450907E2202306A91-8076
1 Fault Found:
002071 - Starter Disable Circuit
P0817 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 174137 km
Time Indication: 0
Date: 2017.03.09
Time: 15:03:58
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 67.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 L HW: 4F0 614 517 L
Component: ESP 8.0 quattro H03 0090
Revision: 00000000 Serial number: 00000000000000
Coding: 0020872
VCID: 2D51EF3FB4E4E5760F5-8078
No fault code found.
Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
Part No SW: 4F0 910 852 HW: 4F0 905 852 B
Component: FBSAUDIC6 ELV H30 0220
Revision: 31050601 Serial number: 10600300137701
Coding: 0000147
Shop #: WSC 00579 210 82600
VCID: E3C5C90722A0E306691-80B6
Subsystem 1 - Part No: 4F0 910 131 E
Component: FBSAUDIC6 EZS H44 0070
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H39 0040
Address 07: Control Head Labels: 4F0-910-7xx-07-H.lbl
Part No SW: 4F1 910 732 D HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 392CL057512372
Coding: 0001002
Shop #: WSC 00000 000 00000
VCID: 2541171FEC14DD36C75-8070
Subsystem 1 - Part No: 4F0 910 609
Component: Bedienteil MMIC6H03 0870
Subsystem 2 - Serial number: 00000000013912
Subsystem 3 - Serial number: 0118.05.040000000100010069ÿ
Subsystem 4 - Serial number: 010069ÿ
3 Faults Found:
01310 - Level Control System Control Module (J197)
004 - No Signal/Communication
Freeze Frame:
Fault Status: 01100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 35
Mileage: 174509 km
Time Indication: 0
Date: 2017.03.19
Time: 16:54:52
02244 - Button in Control Head is Stuck
000 - - - Intermittent
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 174509 km
Time Indication: 0
Date: 2017.03.19
Time: 17:07:44
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 0000100
Bin. Bits: 000
00658 - Control Head
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 70
Mileage: 174405 km
Time Indication: 0
Date: 2017.03.16
Time: 15:43:04
Freeze Frame:
Bin. Bits: 001
Address 08: Auto HVAC Labels: 4F0-910-043.lbl
Part No SW: 4F0 910 043 HW: 4F2 820 043
Component: KLIMABETAETIGUNGH04 0150
Revision: 00000025 Serial number: 00000000124373
Coding: 0001302
VCID: DBB5F1E71AD0DBC6211-808E
1 Fault Found:
00739 - Coolant Circulation Pump (V50)
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 174430 km
Time Indication: 0
Date: 2017.03.17
Time: 08:45:04
Freeze Frame:
Temperature: 6.0°C
Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
Part No SW: 4F0 910 279 HW: 4F0 907 279
Component: ILM Fahrer H14 0080
Revision: 00000000 Serial number: 4F0907279
Coding: 0002121
Shop #: WSC 00352 210 01865
VCID: E6C3D013D192962E8EF-80B3
Subsystem 1 - Part No: 4F2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AudiC6 H04 0150
Coding: 00062736
Shop #: WSC 00352
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0050
Coding: 00141886
Shop #: WSC 00352
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBE7131939
VCID: 1C3732FBDF5E1CFE68B-8049
Address 15: Airbags Labels: 4F0-910-655-8R.lbl
Part No SW: 4F0 910 655 C HW: 4F0 959 655 B
Component: 3E AIRBAG AUDI8RH29 0230
Revision: 06H29000 Serial number: 0037LD062RF8
Coding: 0013125
Shop #: WSC 02325 785 00200
VCID: 275D1D179618CF26F59-8072
Subsystem 1 - Serial number: 6332CSME0958324F7
Subsystem 2 - Serial number: 6342CSME0849086A7
Subsystem 3 - Serial number: 6351HSME065E0D69K
Subsystem 4 - Serial number: 6361HSME066C6647F
Subsystem 5 - Serial number: 6371VSME064D416CT
Subsystem 6 - Serial number: 6381VSME064F7124N
Address 16: Steering wheel Labels: 4F0-910-549.lbl
Part No SW: 4F0 910 549 HW: 4F0 953 549 A
Component: Lenksäulenmodul H07 0230
Revision: 00H07000 Serial number: 90026050580011
Coding: 0102142
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H06 0080
Address 17: Instruments Labels: 4F0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4F0 920 981 M
Component: KOMBIINSTR. M73 H21 0220
Revision: 00300000 Serial number: 64J324G47
Coding: 2049443
Shop #: WSC 00690 067 57207
Address 19: CAN Gateway Labels: 4F0-910-468.lbl
Part No SW: 4F0 910 468 A HW: 4F0 907 468 D
Component: Gateway H10 0060
Revision: 10 Serial number: 120080522702DA
Coding: ECFE73C41B3104
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H44 1060
Revision: 00000000 Serial number: 305CR057576554
Shop #: WSC 00579 210 68277
VCID: 3B75D1677A907BC6811-806E
1 Fault Found:
03183 - Data Media not Compatible
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 74
Mileage: 174500 km
Time Indication: 0
Date: 2017.03.19
Time: 12:54:14
Freeze Frame:
Hex Value: 0x58CE
Hex Value: 0x7FF8
Hex Value: 0x0000
Hex Value: 0x0000
Address 42: Door Elect, Driver Labels: 4F0-910-793-42.lbl
Part No SW: 4F0 910 793 C HW: 4F0 959 793 C
Component: TSG FA H10 0020
Revision: 00000000 Serial number: S(I
Coding: 0001562
VCID: 2A5BE423850AF24EEA7-807F
Address 46: Central Conv. Labels: 4F0-910-289.lbl
Part No SW: 4F0 910 289 G HW: 4F0 907 289 G
Component: Komfortgeraet H18 0120
Revision: 01200018 Serial number: 01003239530000
Coding: 0393971
VCID: 2E53E833B9E29E6E36F-807B
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
1 Fault Found:
01135 - Interior Monitoring Sensors
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 54
Mileage: 174061 km
Time Indication: 0
Date: 2017.03.08
Time: 09:25:20
Address 47: Sound System Labels: 4F0-910-223-AS.lbl
Part No SW: 4F0 910 223 G HW: 4F0 035 223
Component: Amp.-ASK H09 0350
Revision: 19S00001 Serial number: 01003050073467
Coding: 0000103
VCID: 224B0C03FD3A2A0EA27-8077
Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
Part No SW: 4F0 910 280 HW: 4F0 907 280 A
Component: ILM Beifahrer H09 0050
Revision: Serial number: 00000000073583
Coding: 0001113
VCID: DEB3F8F309C2CEEE46F-808B
Address 52: Door Elect, Pass. Labels: 4F0-910-793-52.lbl
Part No SW: 4F0 910 792 C HW: 4F0 959 792 C
Component: TSG BF H11 0040
Coding: 0001690
VCID: 29591B2F800CF956E3D-807C
Address 53: Parking Brake Labels: 4F0-910-801.clb
Part No SW: 4F0 910 801 HW: 4F0 907 801
Component: EPB C63C0030 H03 0030
Revision: C63C0030
Coding: 0000321
Shop #: WSC 02334 785 00200
VCID: DDB1FFFF04C4D5F65F5-8088
Address 55: Xenon Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H02 0010
Revision: 00000001 Serial number:
Coding: 0000003
Shop #: WSC 00579 210 91747
VCID: 3F8DA5776E8867E6AD9-806A
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 B
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 394CU057526581
Coding: 0000001
VCID: 3169F34FA8DC81962BD-8064
Address 61: Battery Regul. Labels: 4F0-910-181.lbl
Part No SW: 4F0 910 181 F HW: 4F0 915 181 B
Component: J0644 BEM H12 0760
Revision: 00000000 Serial number: 00000000000524
VCID: 24470A1BE72E243ED0B-8071
Subsystem 1 - Part No: 4F0 915 105 D
Component: von VA0 2509061131
Coding: 344630393135313035442056413032353039303631313331
2 Faults Found:
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00110001
Fault Priority: 7
Fault Frequency: 4
Reset counter: 62
Mileage: 174098 km
Time Indication: 0
Date: 2017.03.09
Time: 01:56:38
00532 - Supply Voltage B+
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 174142 km
Time Indication: 0
Date: 2017.03.10
Time: 09:49:40
Address 62: Door, Rear Left Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 795 A
Component: TSG HL H11 0030
Coding: 0001026
Address 72: Door, Rear Right Labels: 4F0-910-795.lbl
Part No SW: 4F0 910 795 A HW: 4F0 959 794 A
Component: TSG HR H11 0030
Coding: 0001026
Address 76: Park Assist Labels: 4Fx-910-283.lbl
Part No SW: 4F0 910 283 HW: 4F0 919 283
Component: Parkhilfe 4-Kan H09 0030
Revision: --.--.-- Serial number: 11720506004975
Coding: 0001016
VCID: E1C9C30F38BCF1167BD-80B4
1 Fault Found:
01547 - Sensor for Parking Aid; Rear Mid-Right (G205)
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 3
Fault Frequency: 1
Reset counter: 12
Mileage: 174001 km
Time Indication: 0
Date: 2017.03.07
Time: 15:48:38
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4E0 910 336 K HW: 4E0 862 335
Component: Handyvorb2 H13 0950
Revision: 00000000 Serial number: 00000007598455
Coding: 0010900
Shop #: WSC 02313 785 00200
Thanks in advance.
56 61 62 72 76 77
Coding: 0011372
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 173991 km
Time Indication: 0
Date: 2017.03.06
Time: 10:42:40
Freeze Frame:
RPM: 1008 /min
Torque: 159.9 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.55 V
Bin. Bits: 00101100
Torque: 280.8 Nm
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 174137 km
Time Indication: 0
Date: 2017.03.09
Time: 15:04:18
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.24 V
Bin. Bits: 00101100
Torque: 89.7 Nm
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 174137 km
Time Indication: 0
Date: 2017.03.09
Time: 15:03:58
Freeze Frame:
RPM: 0 /min
RPM: 0 /min
RPM: 0 /min
(no units): 30.0
(no units): 25.0
Temperature: 67.0°C
T.B. Angle: 0.0°
Coding: 0020872
Coding: 0000147
Coding: 0001002
3 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 35
Mileage: 174509 km
Time Indication: 0
Date: 2017.03.19
Time: 16:54:52
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 40
Mileage: 174509 km
Time Indication: 0
Date: 2017.03.19
Time: 17:07:44
Freeze Frame:
Bin. Bits: 00000000
Bin. Bits: 0000100
Bin. Bits: 000
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 70
Mileage: 174405 km
Time Indication: 0
Date: 2017.03.16
Time: 15:43:04
Freeze Frame:
Bin. Bits: 001
Coding: 0001302
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 71
Mileage: 174430 km
Time Indication: 0
Date: 2017.03.17
Time: 08:45:04
Freeze Frame:
Temperature: 6.0°C
Coding: 0002121
Coding: 00062736
Shop #: WSC 00352
Coding: 00141886
Shop #: WSC 00352
Coding: 0013125
Coding: 0102142
Coding: 2049443
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 2
Reset counter: 74
Mileage: 174500 km
Time Indication: 0
Date: 2017.03.19
Time: 12:54:14
Freeze Frame:
Hex Value: 0x58CE
Hex Value: 0x7FF8
Hex Value: 0x0000
Hex Value: 0x0000
Coding: 0001562
Coding: 0393971
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 54
Mileage: 174061 km
Time Indication: 0
Date: 2017.03.08
Time: 09:25:20
Coding: 0000103
Coding: 0001113
Coding: 0001690
Revision: C63C0030
Coding: 0000321
Coding: 0000003
Coding: 0000001
2 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 4
Reset counter: 62
Mileage: 174098 km
Time Indication: 0
Date: 2017.03.09
Time: 01:56:38
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 59
Mileage: 174142 km
Time Indication: 0
Date: 2017.03.10
Time: 09:49:40
Coding: 0001026
Coding: 0001026
Coding: 0001016
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 12
Mileage: 174001 km
Time Indication: 0
Date: 2017.03.07
Time: 15:48:38
Coding: 0010900
I'd recommend the simple things first...replace the battery, since this seems to be a usual sign the battery is failing. Nevertheless, it could be something else, noticed the following error codes:
The regulator failing could mean your battery is discharging improperly and will fail earlier than ususal.
As for the starter issues, well that certainly sounds like the issue you've described, but that error can also be caused by a weak battery: P0817 OBD-II Trouble Code: Starter Disable Circuit - Autoblog
Thanks for your reply Raj99 I have installed the battery meter on the mmi and it shows as full charged and on examination it looks in mint condition and fairly new, although it would as its in a sealed box.
I'll get it replaced as I get them quite cheap any way.
There has been some water ingress issues that I'm also chasing at the moment so its possible they are related.
I suspect its been an ongoing issue for the last owner as its had the control head and ecu replaced at some point.
Will order a replacement battery and report back later.
So we had a few developments with this. Havent managed to get the fuel filter sorted yet.
Battery was replaced issue still present
Let me explain. Drove from Cumbria to Manchester at the weekend noticed a bulb out so stopped at halfords to get one.
On leaving the car park I applied some power the car died and glow plug light came on car wouldnt restart for a few min.
Eventually managed to get it home fine.
School run next day car ran fine on the way there but on the return journey was doing the same thing like it was struggling for fuel. 1/4 of a tank in.
got it home ran scans and amongst a million other codes these came up.
there was quiet a lot of fault codes and I'd begun by this point to suspect all the expensive stuff like ECU HPFP etc
I had noticed that there was air in the fuel system so traced all the lines to see if there was a leak, again fuel filter and HPFP was suspected and now the car would not run at all (fuel line full of air no fuel coming through still 1/4 of a tank)
VIN: WAUZZZ4F46N006392 Mileage: 175120km/108814miles
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: Malfunction 0010
Coding: 0011372
5 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 173991 km
Time Indication: 0
Date: 2017.03.06
Time: 10:42:40
Freeze Frame:
RPM: 1008 /min
Torque: 159.9 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.55 V
Bin. Bits: 00101100
Torque: 280.8 Nm
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 174137 km
Time Indication: 0
Date: 2017.03.09
Time: 15:04:18
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.24 V
Bin. Bits: 00101100
Torque: 89.7 Nm
004195 - Fuel Pressure Regulation
P1063 - 001 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 175112 km
Time Indication: 0
Date: 2017.03.26
Time: 16:02:00
Freeze Frame:
RPM: 2898 /min
Torque: 452.4 Nm
Speed: 14.6 km/h
Duty Cycle: 97.6 %
Voltage: 13.45 V
Pressure: 681.6 bar
Duty Cycle: 56.4 %
P1063 - 002 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 175112 km
Time Indication: 0
Date: 2017.03.26
Time: 16:02:00
Freeze Frame:
RPM: 2898 /min
Torque: 452.4 Nm
Speed: 14.6 km/h
Duty Cycle: 97.6 %
Voltage: 13.45 V
Pressure: 681.6 bar
Duty Cycle: 56.4 %
P1063 - 006 - Control Range Not Reached - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 175112 km
Time Indication: 0
Date: 2017.03.26
Time: 16:02:00
Freeze Frame:
RPM: 2898 /min
Torque: 452.4 Nm
Speed: 14.6 km/h
Duty Cycle: 97.6 %
Voltage: 13.45 V
Pressure: 681.6 bar
Duty Cycle: 56.4 %
This part concerns me as I couldn't cycle the fuel pump from VCDS to eliminate issue
Any how after reading various forums it occurred to me I may have an issue with the in tank jet fuel pump and filled the car up with some spare diesel I had lying around.
Low and behold the car fired up and is now running beautifully.
Now if this part is faulty am I right in saying the car will struggle to start until suction has pulled fuel up through the system?
I think I have found my issue!
Audi want well over 300 for the part so I need to find a cheap or used replacement plus the tool to remove said jet pump sender unit.
I'm struggling to find the part I need, can anyone else point me in the right direction.
The guy at Audi called it an in tank fuel pump but I'm not convinced this s the same thing.
The part I suspect is the sender unit with jet pump ( quattro only) that blows the fuel from one side of the tank to the other over the prop shaft cut out.
This I suspect as the sender is still reading 1/4 tank but one side of the tank must be empty while the other is at 1/4
Coding: 0011372
5 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 173991 km
Time Indication: 0
Date: 2017.03.06
Time: 10:42:40
Freeze Frame:
RPM: 1008 /min
Torque: 159.9 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 11.55 V
Bin. Bits: 00101100
Torque: 280.8 Nm
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 174137 km
Time Indication: 0
Date: 2017.03.09
Time: 15:04:18
Freeze Frame:
RPM: 0 /min
Torque: 167.7 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 12.24 V
Bin. Bits: 00101100
Torque: 89.7 Nm
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 175112 km
Time Indication: 0
Date: 2017.03.26
Time: 16:02:00
Freeze Frame:
RPM: 2898 /min
Torque: 452.4 Nm
Speed: 14.6 km/h
Duty Cycle: 97.6 %
Voltage: 13.45 V
Pressure: 681.6 bar
Duty Cycle: 56.4 %
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 175112 km
Time Indication: 0
Date: 2017.03.26
Time: 16:02:00
Freeze Frame:
RPM: 2898 /min
Torque: 452.4 Nm
Speed: 14.6 km/h
Duty Cycle: 97.6 %
Voltage: 13.45 V
Pressure: 681.6 bar
Duty Cycle: 56.4 %
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 175112 km
Time Indication: 0
Date: 2017.03.26
Time: 16:02:00
Freeze Frame:
RPM: 2898 /min
Torque: 452.4 Nm
Speed: 14.6 km/h
Duty Cycle: 97.6 %
Voltage: 13.45 V
Pressure: 681.6 bar
Duty Cycle: 56.4 %
Clogged fuel injectors maybe?
Let's see, fuel lines full of air is a serious problem on the diesel.
When changing the diesel fuel filter, o rings need to be replaced and one must ensure there are no leaks. There could be leaks elsewhere in the system. Also, people note internal leaks on the fuel injectors causing very similar conditions.
Well here is what official Audi workshop guide says about the "Suction Jet pump"
"If the suction-jet pump is not working, up to 20 litres of fuel (up to about 1/4 of tank capacity) may remain in the left chamber of the tank, where it cannot be drawn into the fuel delivery unit.
If the engine stops due to fuel starvation with the tank up to about 1/4 full, proceed as follows:
– Check fuel pump → Chapter.
If fuel pump is OK, but no fuel is delivered:
– Put another 5 litres (approx.) of fuel into tank.
– Start engine.
If engine now starts:
– Renew suction-jet pump → Chapter.
EDIT: you seem to be in UK? so according what i found your engine code is:BMK
will se if i find that "Jet" part
cheers!/H
– Start engine.
cheers!/H
Thanks for all your advice.
thats pretty much what happened I stumbled across an a4 with similar issue and exact same fault codes. put a load of Cherry diesel in and off she went, car is fine so long as it ha more than 1/4 tank.
Although I think there may be a burst pipe in the system somewhere as there was a rainbow on my drive this morning after some rain.
I tried to run the fuel pump via VCDS to test however I can't access the engine diag due to this error
Unfortunately the Jet pump is well over £350 quid and Audi only part so I'd like to rule out leaks before shelling out on one. Might even bodge a facet pump in for now as the sender side clearly works. i think this may be down to a leak in the lines somewhere.
Will get under it at the weekend and have a proper look. will report back thanks guys for the help so far.
