05 A6 3.2 leaky injector on cylinder one...
Where do I start? Looking to fix this myself and I'm told that with the FSI, injection is underneath the valve cover?
das60 (02-03-2023)
After doing more searching, I've read so far that the intake has to come off and there are several tools used to put the new o rings and seals on the injectors? Has enough time passed for a clever DIYer to come up with a method that doesn't require all these tools?
Thanks for responding... I am told it's the seal and not the actual injector that is leaking so I am looking to see what others have done with regards to teflon seal and o rings. Have people just replaced the orings and call it a day?
any diy pages created for the removal and installation of injectors into FSI engines?
das60 (08-25-2022)
You can always swap out the injectors to see if they are good, if that's the route you want to go.
I'd go the other way and just change the o-ring if that's the leak (which, I must admit, I find surprising). Getting the manifold and fuel lines off is fairly easy. But getting the injectors out is a pain, and the failure rate on the teflon rings is near zero.
