coolant temperature high - suggestions
Old 03-25-2017, 07:14 AM
joedroid78's Avatar
Default coolant temperature high - suggestions
Last week, my 2005 allroad 2.7T auto suddenly gave a high-coolant temperature warning (Gauge said H). After 2 minutes, it went back to completely cold (C) and the warning disappeared. The normal behavior is after a few minutes of driving, it stays in 12 O'Clock position.
This repeated for a few days. Yesterday, the gauge never came back to C and it is staying at H. I don't see any drivability problem or any other issues. My engine temperature is normal.
Any suggestions on what may be wrong? Some sensor issue? If so, what is it and where can i find it? Any help is appreciated
Old 03-25-2017, 06:44 PM
Banned
PaperToast's Avatar
prolly a sensor going out; a vagcom scan should reveal more
Old 03-26-2017, 02:50 AM
amiram's Avatar
Default Electrical contacts
Guess: Clean the contacts in the electrical connecto on the sensor
Old 03-26-2017, 04:57 AM
joedroid78's Avatar
Do you know where I can find this sensor?
Old 03-26-2017, 09:02 AM
amiram's Avatar
Default Engine temperature sensor G62
VW Audi Part number 078919369 On Ebay
Old 03-26-2017, 04:51 PM
Banned
PaperToast's Avatar
not quite what he's lookin for
there are 2 coolant sensors i believe
one is on the lower rad hose, passenger side of engine
and i think the other is the back of the engine, in the middle somewhere
Old 04-05-2017, 04:32 PM
VancouverAllroad's Avatar
I also have a 2005 2.7
Try changing the Temperature sender/sensor.
The part is 5-15 dollars in the US at Rock Auto
My local Audi dealership tried to sell me a new timing belt and cam sensors and valve cover when the car would not start this december. Wanted $6500
I changed the MAF sensor (Mass Air Flow Sensor) $69 and the Green 4 pin temperature sensor $6 myself and problem solved and car starts perfectly and runs like new.
Might be worth a try. The temperature senders fail regularly and will cause all sorts of intermittent issues.
It was about a 3 hour job for a novice like me.
Pete
avopns
12-18-2017 07:26 AM
aessis
11-19-2017 03:34 PM
OlyS4
06-21-2011 12:28 PM
MattC
11-29-2005 01:21 PM
fignewton
TT (Mk1) Discussion
03-12-2004 06:41 AM
Quick Reply: coolant temperature high - suggestions
