Doing maintenance on ill maintained tt quattro
So I just bought a 2002 audi tt quattro and it seems the previous owner didn't do much beyond oil changes, so far I've changed to oil to full synthetic 5w-30 (which I'll be doing again tomorrow thanks to not changing the drain plug), I've ordered tie rod ends, sway bar links, turn signal relay, new coil packs and oem plugs, valve cover gasket, engine air filter.
I was thinking of doing the timing belt soon as I don't know if it's ever been done and car is at 137k but I just don't have the time right now.
As far as catching up with maintenance is there anything I'm missing? I'm new to audi so I'm trying to learn as much as possible
Don't drive the car until you do the timing belt!
Yeah the timing belt was my main concern mostly because I don't know if it's been done and I'm not sure if there are any signs it may be getting weak, I just need a day or two off in a row where I can replace it as I work a lot
There is an easy visual check
The plastic cap at the top of the engine over the timing belt slides off so you can check belt condition and tightness. Unfortunately, the most common cause of failure is not the belt itself but immediate catastrophic failure of the tensioner or water pump for which there is no warning.
Imgur: The most awesome images on the Internet
There's a picture of the timing belt all my cars have used chains so I don't know anything about them really
If you do not already have one, I would HIGHLY recommend buying a VCDS or just a VAG Scanner on amazon like I did for $49.99. It does most of the features that a regular VCDS does, such as recoding modules, scanning codes, and other things like clearing lights. I would HIGHLY recommend getting one as it will cut your diagnostics time in half. It helps so much. Otherwise, seems like you have done most of the basic things, I would change the Haldex Fluid and Filter, and othe than that, it seems like you are good to go!
I learned the timing belt was done at 80000 miles thanks to carfax so I've got some life left on mine but it will be changed fairly soon. I was looking at getting vagcom but I don't have a laptop I currently use a cheap Bluetooth one scanner and torque on my phone but if vagcom is any better I might pickup a cheap laptop or if you know of one that doesn't need one
sabih786
TT (Mk1) Discussion
33
02-20-2009 08:01 AM
