◆ Needs help with 08 Q7 3.0TDI Major Issues ◆
Hi guys
i really needs help from you guys about my 08 Q7 3.0 TDI (South Korea)
so i 've run the Vagcom and i see lots of issues but
I've pulled out some Major issues.
the issues that i'm having now with my baby Q7 are
- it doesn't starts well, I've replaced battery and recycled alternator but keep having same issue now.
- from 1400 RPM it doesn't go up straight to the 2000 RPM when RPM reach 1400, after i press more gas, RPM jumps to 2000 RPM
- when i press gas at FULL position, and RPM go over 5000, suddenly the car get into the limp mode and the Glow Plug System warning symbol shows up.
when this happens, i just shut down the car and restart and warning light gone, and car runs fine.
- feels like my car lost power a lot.
what i have done to my car is.
ECU Malone Tuning Stage 1
K&N Air Filter
this is all i've done to my car with modification.
these are the Major codes that reading on My Q7
Engine (CAS)
000135 - Fuel Rail/System Pressure
P0087 - 003 - Too Low - Intermittent
004142 - Torque Restriction due to Exhaust Temperature
P102E - 000 - Intermittent
Airbags
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
02095 - Component Protection Active - Intermittent
Aux. Heat
01414 - Combustion - Air Blower (V6)
007 - Short to Ground
02251 - Heater Unit Locked
CAN Gateway
01207 - Control Module for Auxiliary Heater (J364)
004 - No Signal/Communication - Intermittent
Battery Regul
02256 - Quiescent Current
001 - Upper Limit Exceeded - Intermittent
03041 - Energy Management Active - Intermittent
★ All VCDS Report is Attached please have a look ! ★
I've spent a lot of money on my baby at least $35,000 to repair
i wanna keep this car forever with me =)
please help me to get my baby on the road with me again with great health
Thank you all <3
K&N Air Filter
Engine (CAS)
Airbags
Aux. Heat
CAN Gateway
Battery Regul
Thank you all <3
Many of those date back to 2016 so it cannot have cleared the fault log.
Can you try clearing it again then download the faults again after a couple of days driving?
tyluk
11
08-17-2009 02:41 PM
kilburn
07-09-2002 03:36 AM
