View Full Version : A4 (B5 Platform) Discussion
- NO: Converting back to quattro from rear wheel conversion
- Avant vs Sedan
- External control buttons diagram
- Fluctuating boost when accelerating
- UK: Boot access?
- Noise when Accelerating
- Speedometer oscillating or fluctuating on constant speed
- GR: Quick Help with a car part for my Audi A4 B5 1.6 ADP
- Baro code
- A4 2014 Bluetooth Music
- battery accident: cross-jumped, now starts but dies when applying throttle
- High crank case pressure
- 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
- 2003 Audi A4 Convertible Trunk not opening!
- Headlight washer replacement
- Weird ABS problem, ABS and ESP light on need help
- Low Bass Volume
- IT: AC is not starting
- Vehicle side brown O2 Sensor connector 3A0973304A
- Rev Hesitation
- B5 no-start
- Oxygen (Lambda) Sensor; B1 S2 ISSUE
- 2008 Audi A4 Quattro making loud grinding noise when cold start PLZ HELP
- radio types and bluetooth module
- 2024 Davisville Port Delays
- 058 block to 06A swap
- Obd not connecting to ecu
- Eletrical issues
- Brake Light Issue
- Audi A4 B5 ADR CV Joint
- Persisting Rough Idle and Vibrations After Engine Mount Replacement with Lemforder
- Seeking front driver side Xenon headlamp Control Module
- Interior swap b6/7 to b5
- A5 Cabrio Headliner
- A4 b5 cuts out when accelerating and starts bouncing to 1.5 sometimes
- A4 1.8 Mystery Plug
- A4 B5 1.9 TDI AJM low oil pressure warning light
- From Jap to German. New owner
- Weird miss
- Large Oil leak
- Random misfiring
- removing old gas from the tank
- 1.8T FWD Upgraded Downpipe?
- A4 1.8t - no spark no fuel power problem
- Another heat problem
- 23 Years - My best car, ever.
- 2001 A4 Avant Ballast
- A4 B5 audio works when cold, slowly gets quiter, dissappears completely
- A/C unit blank, no screen light
- Looking for ADR cylinder head or cams from one.
- no power at all
- Tachometer not working, Speed sensor implausible signal
- Evap line or vent line?
- ABS BRAKE Lights on...
- Looking for new engine cover
- A4 B5 clunking noise when going over bump
- A4 B5 Auto gear selector
- getAudiparts.com | Black Friday/Cyber Monday '23 Savings are Live!!!
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- 1999 A4 B5 rear defroster just failed
- ZA: Audi A4 1.8 B5
- Audi map of Europe
- SE: Audi A4 B5 2000 FWD Handbrake not working.
- Why is my transmission failing with no previous signs? And no error codes
- Trunk US
- Steering wheel
- Audi a4 1.8t Quattro o2 sensor issue
- Sunroof issues audi a4 2007 quattro
- Ticking sound from one of the fuel injectors when ignition is in the ON position
- UK: Chucking in any gear across all speeds?
- Difficult to pull out of 5th gear on downshift
- Proactive coil pack replacement?
- Unknown Loud Beep
- Locked key in the fuel tank door of 05 A4 and the car is locked
- 98' 2.5TDi V6 Auto Rev/Shuts Down
- CEL and List of Codes
- B5 A4 V6 very hard start after parked for a week
- 97 AFC TCM TCU FAULTY whats tcm are compatible?
- 97 AFC 2.8 12v SOHC flywheel
- Audi A4 B5 2.8L AFC Gearbox problems HELP!
- A4 B10
- Breaking cv shaft
- HR: 1998 Audi A4 B5 1.8 naturally aspirated cold start issue
- Blower motor smelling burnt and blowing fuse.
- What is this noise?
- Audi stall-misfire
- HU: Brake caliper upgrade?
- wiper relay problem
- factory hid headlights
- Coolant Leak
- Where is this coolant hose attached to?
- B5 2.8 clutch bleeding problems
- 01 a4 AWD key fob wont program
- Fully refreshed A4 B5 Avant 5 speed on Cars & Bids with NO RESERVE!
- UK: Audi Quattro too low
- Auto gear selector
- 1998 Avant 2.8 30v no start help please
- Is it possible to set service notification to 10000km instead of 15000km?
- Mercedes wheels?
- Bought a 2000 A4 Avant Quattro
- New 17z/18z setup grinding noises and rough ride
- Time to replace struts?
- Radio conversion
- Ignition coil.
- What is this wire sticking out of my AC compressor?
- Special tool for strut mounts A4 1.8 t ?
- My alarm system keeps going off at random times
- Boost fluxuation problem
- 1998 A4 Front Differential,Transmission & Torsen Question
- 2010 a4 2.0 white smoke, cel, and epc
- Can the headlight adjustment posts/screws be repaired?
- Need bumper cover Canada
- Sport seats in 1.8t
- 2001 Audi 1.8T not starting
- Boss 100 watt amp
- Climate control problem
- Humming noise coming from right side of trunk
- 2000 A4 Central Locking Wiring Diagram
- Pump Closing Centralized
- Diagram for interior self dimming mirror 2001 A4 1.8T B5?
- Cluster LEDS
- UK: Possible diesel leak from Engine
- How do I pinpoint the source of a small rattle from a pulley?
- 18z on B5 A4
- Audi a4 b5 1.6 idle gas
- Burning oil and Misfiring with strange problems
- Luggage compartment interior light ground wire
- mismatch engine code
- Leaking or burning oil???
- A4 B5 a/c compressor not turning on?
- 2001 a4 quattro with awm 1.8L no crank no start after engine replacement
- Greetings from SuperSprint Italy
- Trying to identify Bilstein coilovers
- A4 B5 ACCY FOR RADIO
- P0010: camshaft position actuator circuit open bank 1
- Fuel line part #
- Won't rev
- Help! Partial crank!
- PLEASE HELP!! 08 A4 Quattro 3.2
- B5 S4 purchase!!!
- Wiring harness identification- audi a4 b5 2001 2.8l avant
- UK: A4 3.0 TDI NO DRIVE
- Engine revs to redline at idle, no gas pedal pressed.
- Huge vibration from cv axle
- Can I swap my b5 1.8 with a b6 1.8?
- Audi A4 B5 sport suspension springs availability.
- 6 speed swapping a 1.8t 5 speed
- Audi A4 B5 intake manifold cleaning 1.9TDI 1Z engine code
- Possible Audi A4 1.8T Manual Performance Upgrades
- ESP/ABS & park break malfunction
- Cluster swap
- Fuel injector polarity?
- Can anyone tell me what this is???
- 4 misfires, EPC, limp mode and 4 other codes
- ZW: Problems with my Audi A4
- Potential ABS block leak
- Window seal problems after respray
- CV Axle - Couple of bearings fell out of inner joint
- Where can I find this steering column bolt?
- In search of....
- WTF IS THIS BUTTON ON DRIVER SIDE CENTER PILLER?
- Calibrating instrument cluster's gauges.
- Help needed folding mirrors
- HR: Audi a4 b5 1.6 idle gas
- clutch fan pully causing acc belt to shread
- UK: Improvements, not mods?
- 1999 2.8 New Buyer Discussion
- Faulty Cruise Control Stalk - Replace or Refubirsh?
- Replacement bumper and general bodywork for 2001 A4
- 98 1.8tQ removing alternator HELP!
- AWM ECU into AWP GTI
- Looking for 12v intake part
- '98 A4 fuel level sending unit - unobtanium?
- Fuel line help.
- 2001 2.8 V6 P1479- Brake Boost Vacuum System: Mechanical Failure
- Running rough jerking and shaking still after changing parts ftom codes p0304 and p01
- B5 swap
- LV: audi a4 b5 fl stock stereo to bose
- Heater Core Return Hose 2.8 ATQ
- Tune for 2.8 v6
- Fuel door locked due to central locking failure, how to put gas in car?
- Audi Overheating and white smoke out of exhaust
- Upgrades?
- SE: How to find wiring diagram for Audi A4 2.6 -96 4-speed automatic?
- Audi A4 b5 2.8 FWD - 5hp19 RPM drop in 2nd gear
- Head gasket replacement?
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- 99 Audi A4 B5
- A4 b5 chain tensioner
- AGM battery in 97 A4
- Car cranks but wont start
- Noise when turning in wet conditions
- ECU Swap Recoding
- 2000 A4 2.8 Motor rebuild shop in MD?
- Car cranks but will not start after heater core replacement
- ZA: Audi A4 B5 1.8 Auto
- B6-A4-3.0V6-6SPD-Quattro Vibration/Steering
- hood fitment
- Audi A4 1.6 ADP 74KW RADIATOR
- Audi A4 B5 airbag 65535 error code help
- Black Friday // Cyber Monday Sales on now – Bright error free LEDs @ the best prices!
- A4 B5 not connect engine ecu
- Fluttering/flapping noise when accelerating
- vacuum
- Headroom for helmet
- B5 BOSE front drivers door speaker crackling
- Starter kicks on and stays on when battery is hooked back up.
- 98 2.8Q stumbles when warming up...not sure where to look
- 99 Audi A4 2.8
- A4 B5 1.9TDI AHU Engine Mountings question.
- Heat and Center vents not working
- 1.8T A4 wont get to temp and throws code
- Questions on B5 Steel Uprights to B6 Aluminum Uprights & Brakes Upgrade
- Turbo leak
- Hesitation at 1,800 RPM
- CZ: Audi A4 B5 V6 2.6 bad idle
- A4 WATER LEAKAGE. ANY SOLUTION?
- Audi B5 1.8t quattro ESP
- Audi A4 B5 1.9 PDTDI (AJM) no CEL light on
- Dashboard lights
- Rear license plate brackets
- Already put $2,000 down. What do you guys think?
- Transmission help
- Blowing Fuse 29, only other symptom is a jumping RPM needle.
- 2006, a4 fuel pump related question
- brought my A4 back from the dead
- BG: Terrible rasp on higher RPM - 1.8l
- Crankcase Breather Hose Coupler/Connector Replacement
- PT: AC Not turning on!
- Code p0012 periodically 1.8t
- 1.8t cam chain rattle
- Brake light/ cruise issue related?
- Check Engine Light Turbo Issue
- A4 B5 flashing brake warning and ABS on
- 1.8T A4 cranks but wont start
- Knocking on Cold Start, bad MPG, and slow
- HELP idle issues
- Drive shaft
- SE: 1.8ts Quattro Agressive jerk when letting go of the throttle
- 01 A4 Avant timing belt issues
- Ac compressor draining and filling
- Concert Radio Codes
- Can anyone identify the broken hose connection 1999 a4
- Leased A4 crash - need advice
