View Full Version : TDI Discussion
- A7 2014 TDI (Help)
- 3.0 TDI (CATA) oil - TRIAX?
- Replace engine or move on or???
- Audi A6 C7 2.0tdi temperature fail
- SE: TDI engine for short distance travels?
- UK: 2.0 TDI ultra engine no power
- 2.0TDI sudden power loss pls help!
- Help navigating warranty repairs
- 3.0 TDI oil pressure issue
- Audi A8 TDI 2015 timing belt/chain issue
- C5 a6 geaebox help!
- Tdi engine swap?
- a3 2.0 tdi engine bkd
- 2012 Q7 TDI - P0087 - Fuel Rail/System pressure too low - at idle
- Serpentine Belt removal issues
- Glow plugs light flashing and check engine light
- 2015 A6 CNH 2.0tdi: Sudden loss of revs and rough idle
- BG: AUDI A4 2.0TDI CSUA 2014 Loosing coolant through expansion tank vent
- Timing chain replacement on 3.0 Common Rail TDI engine.
- Audi A8 4.0TDI weird noise
- Rattle in Q5 TDI engine.
- How to remove T30 bolts?
- Booster solenoid location
- TDI Door Decal
- Brand new Audi Q7 TDI just getting released
- Boost/Hesitation Issues
- Glow plug light flashing
- CPNB vs CGQB difference.
- Engine dead - snapped belt
- A5 CGLC timing belt tensioner high?
- B8 tdi 143bhp misfire under high load
- S4 3.0 TDI 2022 - Engine sound
- New Member with a few Questions
- TDI turbo actuator throw?
- Malone/Tunezilla TCU tune
- Lost washer in motor?
- A3 8V 2.0TDI rattling noise when cold
- Audi a4 b8 tdi avant won’t start
- 80 b3 tdi conversion
- 3.0L TDI EGR Temp Sensor
- 2014 SQ5 TDI injector leak, juddering/shaking while accelerating
- SE: 2014 SQ5 TDI
- 14 3.0 TDI Quattro. How to diagnose coolant leak
- 3.0 BiTdi 2011 Breaking plastic cooling system components
- programer?
- Audi B9 2.0 tdi timing belt + waterpump
- Audi Offers to Buy Back my Q7 TDI for pennies. Need Advice Please
- UK: p0087 Ideas
- A4 2.0tdi (CAHA) Not Starting
- 2015 A3 2.0 TDI Reliability
- 2.0tdi cjcb engine swap
- P240F code or: how I learned to stop worrying and love the Check Engine Light
- TDI Mechanics in Los Angeles area?
- glow plugs - 2013 Q7 tdi 3.0
- labor cost - 3.0 TDI Injectors
- 3.0 TDI 2013 Q7 - Common Check Engine Light
- 2013 Q7 TDI harmonic balancer
- Weird Turbo Behavior
- Bi tdi ruff
- Starnge 'coughing' noise from SQ5 intake pipe
- 2009 3.0 TDI (171KW) Turbo 'switching off'
- Fuel Filter Change Query
- Water Pump Replacement Q's
- tiptronic shift into 4th gear is not smooth
- Violet coolant turns rusty orange
- EGR Cooler Gaskets
- Emissions Warranty if not yet updated?
- 2.0 L TDI - Oil Pressure Warning - False
- 2011-2013 3.0 TDI Concerns?
- Workshop manual?
- Compression test on Diesel engine 3.0TDI
- Poor regeneration of DPF
- 2012 Q7 DEF Controller Location?
- 2011 TDI: BEST SEALANT FOR UPPER SUMP LEAK?
- Timin Chain
- Doing a DPF & EGR delete on my 2014 Audi A6 3.0 TDI
- GT17 Turbo question
- US: New(to me) 2016 A6 TDI
- 2015 Q7 TDI Engine swap
- Upper sump oil leak prevention?
- Cylinder #6 Glow Plug Circuit
- Engine rattle on start up
- Audi A7 3.0 TDI Issues - Looking for help
- IS: A8 D3 3.0 tdi Electronic Throttle Control
- Car struggles to start and white smoke
- UK: Audi A6 (2014) 2.0 diesel - Turbo under boost issue
- 1.6TDI Coolant Loss
- IE: A3 diesel
- RS: 2 destroyed turbos in 2 days, diesel
- Audi start stop function
- Cant find fuel pressure regulator audi a4 b7 2.0 tdi bre 2006
- A8L 3.0 TDI occasional hiccup?
- What color container for methanol?
- White Salt-like buildup ?
- 2015 Q7 Coolant "Flood"
- Particulate Filter - diesel
- Q7 not starting
- UK: Audi a4 quattro 2007 diesel pump issue
- cooling diagram
- AU: Cuts on hard acceleration
- Rattling noise first 5 mins when I turn on fan
- Intermittent Starting Issues
- 2014 Audi A6 3.0 TDI - EGR adaptation?
- pronounced whistling noise 2017 Tdi Ultra
- Audi A4 TDI 2016 110kW
- UK: TDI 2.0L Cab Help Needed
- High Pitched Noise from Gearbox
- Audi 2015 A8 TDI 106,000 miles transmission oil change
- Audi A4 Allroad ticking noise when accelerating
- 3.0 TDI add blue err code
- V-belt moves left and right
- Strange noise from the engine - Audi A4 B8 2010 3.0 TDI CCWA
- Loud noise audi a4
- Volkswagen engine?
- NO: B8 stops
- TDI Warranty: Don't Bank on the Long Block (engine)
- SE: 2,0 Tdi Engine sound like washing machine
- 2014 Q7 purchase?
- Audi Q8 engine noise
- Audi a6 c7 3.0 TDI dct downshifting problems
- A6 C7 2.0 TDI 177HP not too loud?
- Locate Exhaust Gas Temp Sensor
- RS: Audi A6 diesel: engine number?
- Audi Q7 2007 BUG, Coolant Leak From Injector Breather Port
- TDI & Extended Warranty
- Audi A6 C7 rotten eggs / sulphur smell from air vents
- P2185 Coolant Temperature Sensor not being covered under TDI warranty
- SE: Part numbers for 2.0 TDI 177 hk 2012
- LV: audi A8 D2 1998 2.5L diesel, cant rev past 4000 rpm
- Fault Code Ideas
- Audi 100 c3 2.5 tdi AEL swap
- FS: Complete Rawtek exhuast
- GR: Q2 1.6 diesel issues
- Low and Overfill Oil Warnings
- Engine oil
- Whistling sound
- 2008 3.0 TDI Odd Coolant Leak - Coolant in Oil.
- 1.6tdi cayc audi a3
- CAR BROKE DOWN FIRST DAY
- Refurbished engine. Break in
- NO: Break in period advice? 2.0 diesel A3, Refurbished
- audi a5 shaking when cold between 1400-2000 rpm
- P200200 help!!!!!!!!!
- 2015 A6 3.0L TDI Darkside Turbo and Tune
- Audi A6 C7 2.0TDI Ultra Turbo Boost/MAP Sensor Location
- FI: Audi a5 2.0 tdi 2013 engine problem.
- Audi a4 2.0 TDI, loss of power, black smoke
- Is Combustion Leak Tester Fluid result 100% accurate?
- FI: Audi A5 2.0 diesel shaking around 1300-2000 rpm
- 2016 Q5 3.0 tdi diesel purchase question
- Car feels like stalling when moving off from idle.
- 2014 Q5 TDI
- Fault code P063800 on A4 3.0 TDI CAPA engine Help needed!:)
- AdBlue
- BPW to BRD engine swap
- Fault code P001E on 3.0tdi capa
- A6 c6 2.7 tdi bpp turbo actuator problems
- Shakey idle
- 15 Q7 tdi adblue issue after 2020 reflash
- 3.0 DIESEL A4 ENGINE NUMBER LOCATION
- Water pump leaking / poss DIY
- Chipped A3 2.0 TDI 140hp "Chipped" to 185hp-IS THIS STUPID?
- Is this normal? Q7 TDI
- 2014 2.0 TDI or 2010 3.0 TDI
- BLOWN ENGINE TDI Thoughts? incl. photos!
- 2.0 turbo only works when release and re-engage throttle
- 2014 3.0 TDI Q7 Injector replacment
- 3.0 Tdi surge
- Audi B8 2.0 TDI CJCD EA288 Oil Leak
- 2014 Q5 3.0 TDI coolant regulating valve
- Audi A5 3.0TDI V6 176kw squeaking noise.
- Help with battery, coolant pipe, and suspension level sensor
- DEF Fluid
- BRE 2.0 TDi
- Audi TT 2.0 TDI 2016 (MK3) Oil and filter change
- 3.0 TDI tuning box, who's best?
- Audi 2015 TDI 85,000 miles needs brakes
- 2013 q7 tdi engine pros and cons?
- AU: A6 2.0 TDI BRE balance shaft failure?
- A8 2.5tdi AFB
- FI: What is this?
- Custom fuel job on 2004 A4 3.0L
- 2014 Q7 TDI Fuel filter change
- A8 TDI as a vacation house car
- 2.5 injection pump swop & Channel 50 adaptation
- 3.0 partial throttle hesitation
- Audi a3
- Turbo load varies ?
- Exhaust Gas Temperature Sensor fault
- Question Regarding Dealership Servicing
- 3.0 TDI Emissions Recall (new)
- Audi A4 2.0TDi Whistling noise at accelaration
- audi a6 c6 check engine light
- Questions re 2014 A7 TDI
- 2014 Q7 TDI ACnot working
- 2016 Q5 TDI Lemon Buyback with AofA
- Injection pump timing under acceleration
- NO: Bleeding fuel system 2.5tdi
- Glow Plug Lit Up and No Power
- Q5-tdi
- 2014 Q5 TDI adblue
- A3 2.0 16V 103kW (2010) - Noise when engine is cold
- Ever wonder where your bought back TDI went?
- Used Q5 TDI with few miles added since 2016?
- DPF Clogged
- Busted sump 03 1.9 tdi
- Audi A3 8p Quattro 140hp Engines?
- California Lemon law ?
- TDI's being released for sale by VW group
- audi 3.0tdi make knocking noise when start driving gold engine
- Q5 2.0tdi 2015 Whining noise
- p3085
- Audi A6 avant 2007 2.0 TDI 136HP
- 2.5 tdi 132kw Quattro fuel pump
- 2.0 TDI, CAGA, B8 cold start problems
- Audi A4 2.0 TDI with unsprung clutch
- TDI Settlement question
- DPF / No DPF?
- Audi A3 8P1 2.0TDI 140hp BMM vibrations and shakes!!!
- UK: 2016 a6 tdi manual shuddering after driving for 1 hour
- buy a non-fixed TDI?
- TDI vs Gas
- 2.5 TDI AEL/AAT - set injection timing?
- Audi A3 1.6 TDI strange noise ?
- Sweden: Starting problem A4 2009 3.0 tdi Quattro
- Audi A6 2.5TDI 132kW Quattro coolant volume
- Glow Plug System warning light/loss of power
- Audi A7 3.0 TDI Questions
- Degraded fuel economy on fixed 3.0 liters
- Surprising Arrogance and Incompetence From TDI Settlement Office
- Audi 3.0 TDI v6 vs. Mercedes V6 Bluetec Diesels
- How many Psi (or mBar) is the turbo pressure in 1.9PDTDI motor (AVF)?
- How is the 3.0 TDI? I would like to hear from some high mileage people
- 1994 80 Avant 1,9TDI missing oil
- Audi A4 B8 8K cooling system explanation
- p229f code
- q7 3.0 tdi 2011 CLATTER
- Audi A4 B7 1,9tdi Delay in Start when turning over
- A6 diesel: Serpentine belt breaking. Cant find answer
- 1996 1.9 TDi (90 bhp) running cool
- 2.0 TDI Intake Air Temperature Sensor Location
- Audi A6 2.0TDI S-tronic (190PS) turbine problem
- Q7 oil mixing with diesel
- Gearbox problem(?)
- Engine mount bracket
- 2.0 TDI rough idle solved
- 2003 ake 2.5 tdi cam caps
- Glow Plug Light Flashing 1 Week After Cambelt Change?
- surprised there isn't a thread just for TDI debacle...
- "Strong Demand For TDIs"
