View Full Version : 4.2 V8 Discussion
- 2011 S5 engine stutter and occasional stall
- 4.2 l oil leak
- 2010 Audi B8 S5 6MT Fast Intentions Non-Resonated Exhaust clips
- 2015 S7 Engine Starting Problem
- Feedback on swapping 4.2L engine from 2009 S5 into 2007 S4 4.2L Cabriolet
- CDSB engine
- 4.2 v8 5sp manual
- B6/B7 S4 Rear Mount Turbo Kit Dev
- 4.2fsi 2007 P0018 and shaky idle
- audi s5 bogging problem's and rough idle
- Why so expensive, other options?
- valve-engine block breather
- 2012 4.2 FSI startup/idle single cylinder misfire questions
- 4.2 non fsi intake manifold swap to a fsi?
- engine number (s8??)
- RS6 Misfire Issue
- Intake manifold flap issues
- how to change this odd rear main seal
- 4.2 B7 S4: slight loss of power/quieter than usual
- 2012 S5 4.2 lean bank 1
- 2008 Audi S5 4.2 V8 reliability
- PL: 4.2 mated to fwd geatbox
- 673-9032 Coil on Plug mechanical fitment
- Dual mass flywheel replacement / timing chain
- B4 S4 - Slight misfire, no codes, no power loss
- Car won't start
- 2007 4.2 FSI (BAR) random misfire #4
- 40v chain engine - worst designed engine ever?
- HPFPs not coming on Periodically
- Limp mode /esp fault
- Vaccum pump and misfires
- 4.2 FSI - P0016 and engine clatter
- Need Audi 2003 a6 quattro 4.2 V8 hose diagram
- 2012 Audi A8 Quattro 4.2
- Am I wrong or right? 4.2 sensor or chain guide?
- V8 4.2 FSI 2013 P0010
- Upper oil pan leak
- 2005 Audi A8 4.2 Quattrro not turning over but have battery power
- MIL on
- 2012 A8L coolant leak
- Starting Problem
- 07 Q7 4.2 FSI knocking
- Engine sensor connectors
- Q7 BAR 4.2 crankshaft timing mark
- Is 85 inch*lbs too tight for valve covers? (both sides leaking)
- 4.2 BAR cam adjusters
- 2004 A8 4.2 l petrol engine
- Audi A6 4.2FSI Cylinder shutdown
- 4.2 FSI Oil Cooler with removing engine mount
- 1991 3.6 pt V8
- Water Pipe Not Lining Up
- 2008 Audi S5 4.2 V8FSI - Running very rough in limp mode
- Broken timing chain? Please listen to video
- 4.2 and ECP light, HPFP?
- wiring issue 4.2 abz swap
- Help with THAT thermostat bolt
- 09 4.2 Oil Filter Cannister Leak
- OBD2 code P0420
- Need help with p0018 and misfires 4.2 FSI
- Intake Manifold Q7 4.2 Liter (compatibility)
- 2006 A6 4.2 coolant leak
- Audi V8 bellhousing bolt pattern
- 2012 Audi A8 4.2 Intake mainflold flaps P2004 &2005P
- 4.2 FSI Vacuum Diagram
- Audi Quattro Tyre Size different Front/Back
- Dreaded "chain" noise
- Anyone remove a B8 S5 4.2 without the transmission?
- Sudden fuel consumption increase
- 4.2 TDI Engine Clicking or Tapping Sound
- When do I do a carbon cleaning?
- Audi A8 2004 4.2 D3 V8 Turbo ?
- Audi 4.2L v8 (BVJ) Oil Leak/ Adjuster Solenoid DIY
- Which one? 4.2 40v. or 4.2 FSI
- Audi S4 B7 (2006) - Cranking but WONT start
- Coolant full flush/drain
- 2008 A6 G28 Fault (Incorrect Correlation)
- ECU swap gone wrong 2011 S5 - Got a automatic ECU
- ECM failure?
- Carbon Cleaning in Los Angeles / 310 area
- Easier timing belt replacement
- 4.2L FSI Rocker/Lifter Removal
- flywheel bolt pattern
- 2010 S5 4.2l will not crank
- 07 4.2 A8
- What fuel pressure specified?
- 1998 A8 D2 4D
- EPC/Warning light/Coolant light = Water splitter under the manifold????
- Engine number
- Missfire on the cylinder 3 4.2FSI 2007 allroad
- 07 A6 FSI Engine Oil Cooler O-Ring Replacment
- 16395 error code (autel) VVT valves
- Q7 won't start, or crank, battery fine. Need Help
- BNS & CFSA
- P0020 / 17944 S4 B6
- 07 Q7 4.2 Coil & Plugs
- Audi A4 2009
- RPM fluctuate after letting off gas(coasting)
- A/C blowing hot air
- Intake Manifold flap stuck closed after carbon cleaning
- Hot start detonation 4.2 FSI
- A6 C6 4.2 Battery Issue
- 11 S5 rebuilding engine can't find performance internals!
- 4.2 S5 Engine removal without lift
- C5 4.2 EVAP Smoke machine DIY
- Still Misfiring After Injector replacement, gasket replacement, pcv etc
- 4.2 timing belt change, time and effort
- 2007 Q7 4.2 FSI misfire problems
- 05 A6 4.2 Engine Noise Humming/Buzzing
- Cam chain tensioners 4.2 Audi Quattro 2004 S4 station wagon
- Steering wheel shifters
- s4 v8 cylinder wall worn
- Buying used Gearbox
- best year for 4.2
- Front crankseal replacement
- 2002 S6 automatic to manual: Flywheel bolt length?
- Cam adjuster diagnostic
- 2009 Audi R8 engine rattling sound
- Audi Service Center thinks Head Gasket Blown?
- C4 S6 4.2 V8 Parts Issue
- Fan assembly through the radiator
- Newbie considering 2005 4.2 Avant
- Audi 4.2 q7 petrol injectors 2007
- Expansion tank blew up... Help
- My S4 B6 - No power. Few faults
- Fuel Problem 2010 S5 4.2 B8
- Rail/System Pressure P0087 & Multiple Cylinder Missfires HELP
- Coolant mystery!?
- Need help!!
- Engine noise cold/warm 1to 2 secs.
- Upper timing chain tensioner change outs
- Audi S8 d2 (1998) torque specs (AHC engine)
- 01 A6 Quattro 4.2L V8 -- Timing lock tools
- Variable intake actuator
- B7 S4 Throttle Issues
- 06 A6 Quattro 4.2 TC to drive plate bolt torque specs
- thermostate location
- oil pressure light
- which is better? please help
- 01 A6 Quattro 4.2L V8 -- Timing issues help please
- SOS!! 06 A8L owner. Leaking antifreeze lastnight and ticking from my engine now.
- 2007 Q7 140,000 miles engine gone. Should I replace or start over?
- Porsche 914 ABZ 4.2
- S5 clutch life - replace or wait until failure
- You 4.2 Bnk same as Bhf motor?
- Audi A8L 2004
- Audi A8L 2004
- Epc light
- Audi a8l 2004
- Transmission cooler lines into a new radiator
- 2007 audi s4 4.2 l v8 issues
- 2004 B6 S4 will not start
- Fuel injector pigtail replacement - B6 S4
- Fuel pump regulator
- 4.0 TFSI
- Can anyone identify this part?
- Random misfires, PRNDS all illuminated
- Knocking sounds when revving.
- How Much Risk in No-Pressure Radiator, Theoretically
- 08 A6 P0087 low rail pressure. Thoughts?
- 4.2 startup rattle (vid inside) how bad?
- Oil change Audi A8 D2 -95
- Changing tensioner pads in 15 minutes
- 2003 D2 S8 Coolant Leak
- A6 quattro 04' p0455
- Whining noise
- Intake/exhaust
- 2004 s4 clutch not disengaging
- Tickinng noise driver side wheel well???
- Old/compressed gasket on PCV causing oil leak??
- Oil leak
- Engine Timing Problem
- My1staudi
- 2004 a8
- Audi s5 2008 V8 bank 1 no compression
- s8 engine down
- B6 S4 Shaking Alternator
- 4.2 V8 Oil Usage Problem
- B6 S4 VAG-COM - Block 93
- B6 S4 Engine rattle at RPMs
- 2008 Q7 4.2 Misfire problem
- 2006 A6 4.2L V8 Timing chain tensioner replacment
- need help s8 d2
- B7 S4 oil leaks...
- Refreshing a 4.2L
- Another misfire question.
- 4 systems faults !!!
- Audi A8 d3 engine bay wash now electrical issues
- Poor performance s8
- Question about hole under the intake manifold of 4.2i
- Engine swap 2004 allroad
- 2006 A6 4.2 white/blue smoke from exhaust
- 98 A8 Map Sensor location?
- 2005 s4 b7 4.2 strange engine noise
- HELP 2007 Q7 4.2FSI EPC
- 2007 Audi A6 4.2 Misfire Cylinders 1 and 5
- 2005 A8 D3 - it all started with a timing belt replacement
- transmission solenoid fault, dealer say $9200
- 2004 Audi s4 won't even crank over
- should I replace my 4.2 FSI injector o-rings?
- 2010 Q7 4.2l SLine
- Crankshaft locking tool on BNK.
- 2007 Q7 4.2 L engine problems..Help!! please.
- A6 4.2 Vs S4 4.2 Heads
- 2000 A6 Quattro 4.2l won't start.
- 2007 Audi Q7 4.2L
- 2007 Audi Q7
- Non-starting D3 A8
- 2005.5 S4 check engine light
- Thinking of buying 2003 to 2007 A8 with 4.2
- how do I set cam phasers?
- 2006 A6 Sline 4.2 timing chain parts kit
- 4.2 V8 40v to 01e gearbox
- 05 A8 4.2 BFM front main seal
- 05 A8 BFM oil seals
- 1997 Audi A8 4.2 v8 has misfire
- C6 A6 4.2 chain guide life?
- 2005 S4 B6 Stalls randomly
- 1998 Audi A8 4.2 Running problem
- 07 Q7 4.2 help PLEASE
- Nickel sized piece in oil pan
- Missing Cam Cap E4
- Oil in intake manifold?
- Codes P0431
- VAG COM NASHVILLE TN
- Rs6 C5 with S6 C7 engine
- B6 s4 rattle when warm and low rpm
- A8 4.2 overheating when...
- Cayman engine swap
- Blown piston? or valve smashed into piston?
- Is this valves hitting after timing belt change
- Radiator Help 2004 S4
- 2014 Audi S6 air intake
- 2000 A6 4.2L ART with Timing Belt rub noise at cold starts
- Audi S5: P2006 P2007 P2004 P2005 DTC for Intake Manifold Runner
- 2005 S4 standar code 300, 306, 307
- where does everyone get there parts?
- 2007 q7 off throttle noise
- S4 B7 Engine Humming HELP
- Differential Questions, good or bad
- 05.5 S4 4.2 Oil Drip
- 2005 s4 4.2 timing chains
- Good tech'l summary of 4.2's?
- 2008 q7 overheating
- Is it bad????
- 02 S6 Just died
- would a failing torque converter be heard ?
