View Full Version : 2.0T FSI Discussion
- BG: Head noise on idle and cold, need help diagnosing
- Need help to ID metal in engine
- Q5 MECATRONIC OB5.927.413
- P164 B/D codes but replaced switch?
- B8 CAEB intake camshaft noise when rotating engine
- Oil leaking
- 2.0 TFSI CAEB oil pressure issues
- 2018 A6 2.0
- A4 B6 2.0 aut., no crank (ABS & TCU error?)
- Is $3400 CAD a Good Price For Timing Chain Job
- LU: Audi A4 Must Haves / Must Do
- Broken actuator arm- fix?
- Strange sound when start up,. BPJ engine
- Can't get all the oil out with extractor - 2018 Q5
- Misfire, Rough idle, Backfire
- VW Audi Group GEO specs?
- 8V S3 Stalling when cornering with wheel slip
- 2010 Audi A3 Quattro not running
- Random cylinder misfire.
- Q5 DIY Coolant Flush Procedure - w or w/o vac pump?
- Transsmission or Fuel pump or Anything else?
- Q5 Remove Firewall?
- 2010 2.0T FSI Cam bridge bolts
- What is this winding/grinding noise?
- 2015 A4 Intermittent starting problem
- Audi ign advance bouncing
- Parameters for 13 A5
- VIS balance shaft delete +pick up pipe TFSI (quick vid )
- 2012 Q5 w 96K miles - reliability upgrades?
- Massive Oil Leak after Oil Housing Replacement: 2008 A4
- Coolant Leak
- 2010 Q5 misfire cylinder 1
- 2014 A6 2.0 - Ruptured fuel line?
- SE: Bumping noise Audi A3
- 2010 Audi A4 new engine, 0 compression on cylinder 3
- Timing Chain Tensioner 2011 A3 8P- Advice Needed!
- Audi A4 B8 Crank but won’t start
- 2017 A3 can't pump gas in and miss fires while driving
- AU: Q5 2.0 TFSI HATD TO START WHEN HOT
- SK: Water pump broke of a piece
- 2009 a3 idle misfire
- Too lean code, vacuum leak..
- Intermittent P2704 error on Audi 2009 a4 Quattro 2.0L 4Cyl Turbo (CAEB) Fuel Injected
- 2006 audi a3 no crank no start no communication
- 2014 Audi Q5 gaskets conundrum
- can a 2009 b8 2.0 be swapped into a 2008 b7 2.0 and what is required
- 2012 a4 s Line Quattro, turbo noise
- Need some advice, car is misfiring when accelerating!
- My 2010 sounds like a diesel..Is my chain bad? (video w/ sound)
- 2016 Audi A4 E9 2.0 TFSI cold start noise
- Update on my 2.0T oil consumption lawsuit against Volkwagen Group of America, Inc.
- 2017 A3 low coolant flow code
- anyone selling a 2.0T cylinder head?
- Engine rattle worsens with revs
- P0420, bad MPG, shaking when idle cold, pulls forward when in Drive.
- NZ: Audi A3 2004 2.0FSI jumpy idle and engine stopped on highway.
- Found a great 2.0T knowledge source
- Rough running until warm
- Chasing misfires
- AR: The Gen3 b-cycle
- 2019 Audi Q5 2.0 gen 3 Turbo issue
- BA: Audi A5 issue
- EPC light cranks but no start list of part replacments
- HELP! My B9 is showing High Coolant Temp warning
- 2011 Q5 2.0t shuddering... blown turbo? slipping trans? valve lifters?
- What is this I found in my vehicle's splash shield/under cover?
- 8 engine codes after installing Injectors, HPFP
- 2015 A4 with Lean at Idle Bank 1 code
- CAEB Gaskets?
- MINIMUM OIL LIGHT ON
- Whining/Air sucking noise on acceleration
- Audi Q3 Bad Ignition Coil?
- 2011 2.0T_ vs_ 2013 2.0T
- 2.0t Durability and when to hold or fold
- Audi Q5 2011 2.0 TFSI, P01600 after replacing timing chain
- 2011 2.0tfsi nagging misfire
- Feels like it's gonna stall at low speed
- Vacuum leak
- 2006 A3 oil pressure light
- New Engine Swap on Audi A4 B8
- Should I Preemptively Rebuild a CPMA Engine?
- Oil filter dilemma for 2017 Audi A4 2.0T
- ECS flashing and stall (CPS code)
- 2.0 TFSI - low oil pressure after balance shaft replacement
- Need some recommendations.
- Class action lawsuit soft piston rings 2.0T engine
- 2014 a4 engine failure (do I have any recourse?)
- Low oil oressure
- white smoke 2017 A4
- chasing vacuum leak
- 2012 Q5 CAE engine: intake balance shaft not moving
- Turbo replacement
- Febi Timing Chain Kit - CAE - 2012 Audi Q5
- B7 A4 Quattro 2.0T
- 2014 Audi A5 Fuel Issue
- Using a VW Crank Case Vent Oil Separator on Audi 2.0TFSI
- 2008 fsi p0016
- Help Identifying Part on Top of Engine
- Injector Replacement on CPMB Flex Fuel A5?
- East Coast - Piston Job Shop Recommendations
- 2014 A5 2.0T Replacement Timing Chain - Audi or aftermarket parts?
- Post Missfire rough start and rough idle when at temp
- Cluster Temp Gauge reading hot
- Engine Electrical Issue
- 2012 a3 quattro 2.0 oil leak
- GEN3 PCV replacement
- 5W20 instead of 5w40 on Audi A4?
- 2.0TFSI CFKA misfires during load/low rpm
- The real ideal #tfsi #PCV setup for the #audi #ea888
- Clogged oil intake screen question
- Very rough idle tons of codes help!
- Accessory Belt + Tensioner replacement intervals
- 2018 Q3 2.0TFSI - No start
- Help with Audi a4 09 engine issues
- Please Help, 2017 Audi Q7 Start Noise
- Car turns but will not start
- 2013 A5 EPC light and misfire
- 2.0tfsi audi q7 2018
- Issue with low speed pulls
- EPC light and engine power cuts at 2700rpm ? Urgent
- Which engine to choose for a pre owned purchase ?
- 2018 Q3 2.0T CPO clicking noise from engine bay
- Oil Burning
- Intermittent noise and a weird battery light
- RPM while driving going up and down
- Engine overspeed fault
- JB4 Tuner for Audi EA888 Gen4 2.0 TFSI 261hp & 265hp
- Timing cover and right engine mount (2006 A3)
- Oil?
- Vehicle vibrates loudly after replacing rear main seal
- CEL - P034100 - Camshaft Pos.Sensor Circ. Range/Performance
- Safe transmission fill spot?
- Gasket Failure + internal coolant leak 2015 Q3 at 112k miles, 80mi past service
- Need help with car vibration after RMS replacement
- Q5 won’t start PO343 and PO190
- Oil Leaks When Jacking Car
- 2.0 TFSI issues
- Engine replacement
- Lower timing chain cover
- 2006 a4 b7 2.0L oil pressure LOW
- Upper intercooler pipe came off at highway speed
- P0299 and P0303 DTC 2008 audi TT fwd 2.0t fsi
- 2.0t PCV Valve Issues
- 2015 S3 proper mechanical carbon cleaning
- Boost tap point
- P0299, P0302, and EPC
- Epc, CEL & ESP no start
- First time poster – 2012 A3 – Coolant confusion
- Wastegate fixed...maybe
- P0030 diagnostic code
- Broken rocker arm - how to replace?
- A4 B8 Rich condition
- AUDI 2014 A6. 2.0 TFSI Not Starting
- Audi A5 2.0 TFSI - Error: P0016
- Valve seals are possibly bad at 140k miles
- Performance Add-ons
- Q5: A Possibly New 2.0T Oil Consumption Issue?
- 2009 Audi A4 Quattro 2.0 Turbo (CAEB engine code)
- Passat: Someone please help! 2.0t fsi
- B9 A4 2.0 Build - Need advice
- Help Please! anyone...
- ZF 8hp servicing on 2.0tfsi Q5
- UK: 2.0 fsi engine code differences?
- 2.0T warming up - clicking sound when revs go down (Audi Q5 2019)
- B7 2008 Audi A4 2.0 runs rough Need Advice
- Oil pressure warning
- Is Prolong engine (oil) treatment a good idea?
- 2013 Audi A4 Quattro B8 2.0L TFSI sputter during acceleration
- APR stage 3 file gone wrong (limp mode) P11AC and P11B0
- 2007 audi a4 2. Turbo wont go into reverse
- 2007 audi a4 2. Turbo wont go into reverseWasn't
- 2.0 TFSI water pump recall
- 2006 Audi A3 Balance Shaft Alinement
- A5 cabrio 2.0 tfsi quattro
- 2.0 TFSI free play in inlet camshaft hub/sprocket
- What are all the common faults on this motor?
- Non-start condition. Scanned vehicle, multiple DTCs (EVAP N80, ECM relay...)
- A3 Tfsi problem?
- CNC Diverter valve upgrade + DV valve VTA spacer
- CTS Oil Catch Can system REVIEW
- Missing MAP sensor?
- Seemingly related ignition and valve timing issue
- Parking Brake, TPMS, Stability Control lights all on at once!
- 2012 Q5 valve cover gasket diy help
- 2010 2.0T FSI Cam Adjuster Rattle Cold
- 2010 2.0T FSI engine rattle
- 2010 AUDI A5 OIL LEAK
- Coolant expansion tank- sensor connector?
- NO VOLTAGE AT FCM
- Replacing turbo
- SI: A4 TFSI engine wiring?
- A4 TFSI automatic gearbox
- 2.0T TFSI injector electric plug broken
- Question for high performance builders.
- Audi s3 jerking
- Exhaust Valve Carbon Buildup / Blown Valve
- Magnetic camshaft adjuster seal replacement, now misfiring. Help! Help?
- audi TT 2.0 TFSI misfire at EXACTLY 3500rpm
- Small copper particles noticed in oil discard pan
- Random misfire p0300 and p0303
- Few questions about some issues on my B8...
- Valve cover gasket leak
- 2007 A3 2.0T Big red brake symbol in display won’t start
- 2006 A3 2.0 TFSI won't start, lots of codes
- 2.0T Piston replacement or new engine
- 2.0 TSFI Oil consumption help
- 2013 A6 2.0T Slight Misfire...really annoying.
- 2.0T - 4 cylinder engine oil consumption
- DSG tranny whine?
- Flexfuel Engine Differences
- Coil pack boots ripped when changing plugs
- Car making strange sounds
- Misfires
- 2012 a4 2.0 tfsi Engine Assembly torque specs requested.
- 2012 A4 2.0 transmission not functioning
- Reset oil interval on early change? have Audi Care
- differences between 16 and 18 CPMB?
- Engine noise after timing/pump change
- DTC P2279/P0068
- 2018 2.0L TFSI
- Engine problems after timing chain replacement
- A5 Head 06h 103 373 j
- Wheel/rim fitment ?
- Clunking noise when turning, giving gas and releasing the clutch form a full stop
- 2.0T (CPMB) ideal oils
- Engine light p0017
- Ideal Oil Consumption 2.0 TFSI
- Seeking advice for used A5 2.0T engine oil problem.
- Coolant Hose Leak Transmission Radiator Outlet hose 2008 Audi TT MKII 2.0
- 2015 2.0 TFSI (155kw) engine huge fuel consumption after engine swap
- 2010 Audi A4 2.0T Quattro (B8) FTSI - Fuel System Priming
- Missfire underload coils and timing belt changed
- Audi Fuel Additive every 3,000 miles?
- Please help me to deal with g31 on 2.0 tfsi after run over deep puddle
- Turbocharger Boost Solenoid
- Timing chain issue
- 2.0t FSI--Cylinder head bolts....& washers?
- Need a long block for my 09 Audi A4 2.0 Quattro [B8]
- Difference between 2.0T (40 tfsi vs 45 tfsi)
- B7 2.0t BWE swap to other bolt on?
- Buying non-running A4 B7... lots of codes
- 2.0 TFSI random misfire
- 2007 A4 loss of Power
- Will it work
- 2.0t fsi knock sensor location
- 2013 A4 Valve Cover Replacement
- Missfire under load lack of power replaced all coils
- 2009 AUDI A4 Quattro 2.0 P0171, P2279 Codes
- First oil change - 10 months in the lot, should I change the oil?
- 2007 A4 B7 Stalls when hot
