View Full Version : TT (Mk2) Discussion
- Dsg very jerky from take off and 2-1
- Manual Roadster top?
- New DIN stereo
- Audi TTS MAF Sensor Problem
- TCM Failure!? Looking for advice!
- Sign up now for TT Wrst 2024 September 23-27
- Need Help from USA Mk2 (8J) Roadster Owners - Trunk Escape Handle
- UK: HOW TO DO A DSG SERVICE YOURSELF AND SAVE MONEY££££
- Gas pump removal on 2008 Audi TT 3.2 convertible
- DSG Cooler Upgrade And Replacement!!!!
- U0103 tt 8j Quattro 2.0 tfsi
- Audi TT wheel size
- Rattling Noise and Sudden Power Loss - 08 TT 3.2
- Convertible top replacment
- AUDI TT MK2 8J PROJECT KO3 =300bhp
- MK2 TT-S saved from the scrapyard
- just finished detailing
- EPC then low oil pressure warning at low revs only after driving at high revs
- Spare tire
- Need Help from USA Roadster Owners - Trunk Escape Handle
- 2015 AUDI TTS RADIO INSTALL
- AUDI TT MK2 8J PROJECT GETS STAGE 2+ TUNED 🔥🔥🔥🔥
- Leather Shift boot
- Help with a unknown noise
- AUDI TT MK2 8J PROJECT FIRST DRIVE !!!
- AUDI TT MK2 PROJECT IS MAKING BIG PROGRESS
- Crank Sensor going out?
- VIS balance shaft delete +pick up pipe TFSI (quick vid )
- AUDI TT MK2 PROJECT CONTINUES (update) 🔥🔥🔥
- Christmas Holiday Sale
- Radio with navigation turns on, but no sound
- VIS Motorsport 2.0 TFSI HPFP Upgrade Install Guide (what could go wrong?)
- DIY- RS4 Fuel Return Valve Upgrade Without Removing Inlet Manifold 2.0tfsi
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- Update: Mk2 Audi TTS
- Safe/good to use 8Jx18 +35 wheels on my 2008 TT 3.2L?
- Tail light and turn light failure due to bad ground design
- No fresh air?
- Earth mod kit
- Audi TT RS 8J MK2 Bearing Noise
- TT 3.2 WET DRIVERS FLOOR
- Timing Issues
- Unable to open door from outside when previously locked
- Interior Rear View Mirror issue
- Rear Fog Light Bulb Error: US Spec
- Fuel pressure too high at idle
- Is the door panel steel or aluminum?
- 2010 Audi tt K04 upgrade problems.
- releasing mounting clip on ABS bracket
- red lead in boot area by battery
- Audi TT Limited Edition Italian flag colours
- What engine is in the TTS?
- Timing chain tensioner Audi TTS 2009
- Random MAF and Throttle error
- TT RS Sport Mode Exhaust
- Audi TT Mk2 2012 Airbag Security Code
- Wire loom connection question
- Mk2 NO AC OR HEAT SIR. HELP ITS HOT OUT. CANNOT FIND RELAY LOCATION
- Rear suspension replacement with MagneRide 3rd part
- Driver's window not going down
- replacing magneride for fixed suspension
- Faults for AWD Clutch Pump-fix = $7000? WTF
- Speed related whistle noise
- 2013 TT RS ECU Tune?
- PSA: Check your rear control arms
- Was told the computer needed to be reprogrammed....
- Wheel and tires fit my mk2?
- Mk2 TTRS engine pull
- Replace factory MMI?
- Interior heater not working
- Need help diagnosing engine + drivetrain issues
- Audi TT RS high pitched/whine noise
- 60k Maintenance 2014 TT (purchased used)
- Gearbox whine etc
- Sway bar upgrade
- Rear Light Error (Earthing Issue Fix)Common Problem
- How to Remove Front Inner Door Card Panel (speaker replacement)
- Workshop Manuals For Audi TT 8J
- MK2 8J TTRS Faults
- Odd Issue, need some help. Possible PCV issue?
- Advice Request - 2013 TT S Line DSG Shutter
- Greetings from SuperSprint Italy
- I made this for a bit of fun😂🤣
- GPS connection - Roadster
- Dual Mass Flywheel failure?
- Nürburgring Trip 2023 FULL LAP (part2)
- 2010 TT Transmission Swap
- Nürburgring Road Trip 2023 (part 1)
- HPFP Housing?
- 19x9.5 wheels on 2012 TT Fitment Question
- TTRS Fuel Pressure Fault
- Brake Recommendations
- TT replace Prius daily driver
- 2014 Audi TT Roadster - Oil Chg. Recommendation
- EPC, Check engine Light fuel issue,
- AUDI TT MK2 BIG PROBLEM SOLVED!!!
- Tail lamp… left turn signal stays on…
- UK: Mr?
- Making MK3 Matrix LED headlights work on an MK2 Audi TT
- chips to boost Horsepower and performance
- Clutch problem?
- 2015 TTS oil and filter
- 2010 Tt downstream O2 sensor.
- GR: Fuel capacity has slow repsonse whel fill up
- Last day to register for TT West is Sunday March 19
- Timing chain or bent valves?
- Misfire problem on 2010 Audi tt quattro CCTA EA888.1
- Valve cover snapped bolt
- Wanted: Solar Orange TTS Roadster...
- 08 3.2 AC howl
- 2008 TT rear brakes and rotors replacement
- 08 3.2 Cluster Dead| Starts then dies in 2 second| Scanned codes!!
- TTRS vs BMW M240i
- 08 Mk2 TT Roadster Roof Not Going Down
- P2294 fuel pressure regulator 2 circuit open
- Misfiring in cold weather
- Help identifying a hose
- Wheel spacers for Mk2 TT
- BWA engine fans on full as soon as car is turned on
- Suspensions or shocks replacement
- 2010 Audi TT oil leak question
- Register now for TT West
- Hello from 2009
- TT Seat bases P/N 2012.045.1 and 2012.045.2
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- 08 tt roadster 3.2 read mag shocks...Help!
- Mk2 TT 2008 Sidelight bulbs have melted the actual plastic light fixture
- Audi TT 8J engine seems to stutter and cut out when it has heavy load / full throttle
- 2008 Base audio - No door speakers installed?
- 2009 TT Mk2 2.0T
- MK2 Audi TTS Cam Follower Replacement after 101k miles.
- '13 TTRS manual Transmission Fluid
- TPMS error with coolant gauge failure
- RO: Is a 2.0 diesel quattro from around ‘09 a decent buy?
- Windshield flexes at top, causes wind noise / seal shrinkage?
- Stereo upgrade Options TT mk2
- UK: Audi TT Quatro Mk2 2012 Sport Timming Belt
- Help me understand whats going on here
- UK: Purchasing my first mk2
- Error code P2261 2.0FSI ea113
- Audi tt mk2 rear seat delete.
- Has anyone replaced the headlight lenses?
- WTB: 2012 TT-RS factory 6 speed shift knob and head unit
- UK: Water below battery?
- B&O Amp connector
- Looking for a used ABS module for my 2008 Audi TT MK2
- 2008 tt tfsi wont start help
- DSG Removal on 3.2
- Audi iTT Roadster Parking assistant Chime (Buzzer) location
- Insurance For a 16 year old male?
- Antenna strip? Help please
- 2012 TT RS quattro Coupe
- New Racingline Catch Can setup using the OE PCV system
- ABS Programming Problem
- 2013 TTS 2.0 rattle
- Re-maps...?
- AUDI TT MEET 21/08/2022 @ (Ockham bites)
- TTS - DSG shift issue when HOT
- TTS - Whats the difference between the S gear and S button?
- Driver airbag
- Fuel pressure regulator check engine light.
- Windshield issues?
- TTS Overheating On Track
- TTS tune
- AU: New 2009 TTS Owner - Brake fluid flush
- TTracking iTT
- 2008 TT Convertible Problems
- Mysterious Boost/Power issues MK2 TTS APR Stage 2
- Front lights
- 2008 3.2 TT Engine Valve Cover
- Cam follower
- UK: Rollin' in a TT music video
- Audi OEM IHI-RHF5 turbo vs. HPA K04 HYBRID turbo comparison
- Need Help
- 2.0 TT bleed air radiation system
- The baTTle of Hastings Southeast TT meet 11/6/22 (VIDEO)
- Ac/temperature sensor
- 2013 TT Premium Plus CAI
- Who brought the 2008 Audi TT 3.2 from University Mitsubishi in Davie, Florida?
- Audi TT Roadster 2014 Mk2 - Issue with Top
- 2012 Audi TTS Convertible
- JP: Changing the battery on a 2008 roadster 2.0
- Help me say goodbye to my TT and blow this video up?
- How to Inspect and Replace a FSI Cam Follower (AUDI VW SKODA SEAT)
- High mileage 2012 Audi TTS Prestige, need a shop!
- Hello, I am new! 2012 Audi TTS
- Hit a pothole and a minute later you have a blowout
- UK: Audi tt London to Brighton test run (QUATTROPHENIA)
- Phone book
- Custom head lights needed
- 3.2 Cab vs TTS Cab
- 2008 Audi TT MK2 Radio Question
- Code P2711. Mechanical Gear Disengagement DSG (Dual Clutch Replacement)
- Pulling CCTA engine without opening R134a lines
- 2012 TTS Top not secure error
- Audi TT 1.8 TFSI Mk2 AC issue!
- Spring tune up 2022
- P2433 Any one had any experience with this code?
- Wanted stock exhaust with cats for an RS
- CAT Thieves Put Cigarette Out On My Soft Top (how should I repair?)
- 12V not working
- Car covers for Mk2
- Spring Tune Up 2022
- Relay Locations
- The real ideal #tfsi #PCV setup for the #audi #ea888
- Silently screaming FML--BLOWN head gasket and turbo
- Clicky Noise
- Piston recommendations
- Titanium Mid-Cats For Sale (TTRS)
- Mag ride or electronically adjustable sports suspension. Is there a difference?
- need help finding what engine i need
- DIY resources for 8j TT RS? torque specs etc...
- MK2 Audi TT 3.2l Big Brake Upgrade Fiasco
- Online parts?
- carbon fiber hood
- SmartTop Module
- Audi TT mk2 fan problems??
- Mk2 Audi TT Quattro 3.2l Project Modified Throttle Body & Subframe Install
- Fake blown head gasket
- 2008 TT, 2.0 turning grind/bump
- Who wants the last spot for TT West Rockies Roads August 22-27?
- TTS transformation in the making
- 2008 TT 2.0 HELP!! Replacing plugs and coil packs
- EA888.2 with the RFD ?
- Mk2 dead dashpod help
- Anyone to on skiing or snowboarding trips with their TT?
- Brake Questions
- Tt-rs help
- United Motorsports Haldex Tune @ 4SeasonTuning
- Frozen catch can? Extreme pressure under extreme cold weather? Oil everywhere.
- CTS Turbo Intake Install
- 034motorsports ECU & TCU/DSG Stage 2 Tune
- Wanted: Audi TT/TTS Hood/Bonnet & Front Bumper Bracket
- Thinking of 08 TT VR6 coupe
- HPA Stage 2 Hardware/Software installation
- TT RS top mount replacement
- Satin Grey wheel color code
- AUDI RNS-E NAVIGATION UPDATE AUDI TT 8J 2007
- EPC & CEL
- Audi TT 2008 Mk2 Convertible Emergency Trunk Release
- TT rear running lights sometimes not working
- MK2 Phone
- 2008 3.2 TT Quattro owners manual?
- what brakes will work 2008 TT 3.2
- 2013 TT RS plus - engine code?
- What fuse / circuit to tap into?
