- Automatic rain sensor malfunction error
- 2014 RS5 Cabriolet Ctl Arm/Bushing Replacements
- PL: Audi A5 2013 2.0 TFSI, no crank, terminal 15 problem
- Start-Stop & Auto Hold (Vcds Code)?
- 2012 S5 Cabrio front grill replacement
- 2014 A5 sportback - parking sensonrs stopped working
- Wiring Harness damaged by ECM?
- Help me figure out what I have.............
- UK: New drilled & grooved discs/pads judder
- Is my B8 S5 Totaled?
- Soft top whole roof replacement
- 2013 A5 2.0T S-Line p2024, p2026
- AU: Is my A5 a B8 or a B9?
- 2008 S5 won't start
- Question of parts compatibility for A5
- S5 Car hesitates to go into Drive
- DK: Strange series of electrical errors - A mysterie 😱
- 2013 RS5 b8.5 loud ticking noise intermittent
- Timing chain job tips
- A Cautionary Tale - Purchasing an Android Auto Touchscreen from AliExpress
- S5 MMI Display Replacement
- 2012 A5 Coupe Quattro; Very rough idle
- Chip Tuning Performance Box Tune
- SI: TRANSMISION SWAP, diesel, CVT
- Factory spark plug gaps is .030 but recommendation is .032?
- 4.2 RS5 Intake manifold on 4.2 S5
- 2008 A5 Confusing Clicking sound PLEASE HELP!!
- No Start Issue - Cranks Once and Stops
- 2010 Audi B8 S5 6MT Fast Intentions Non-Resonated Exhaust clips
- 8k1423055cg - Dynamic Steering or Not?
- Whine when turning steering wheel
- Adaptive learning at limit clutches 1 and 2
- Resetting of all adaptation values - All Wheel Drive
- Trunk and door issues
- New Stance SF12 and SF13 in 19" and 20" Sizes - Wheel Designers
- AMI Aux Input Issues - Speaker Balance
- 2010 Audi S5 4.2 knocking
- 2009 Audi A5 quattro front bumper mount/bracket help.
- Headlight panel wiiring diagram
- AU: B8 8TA 4.2L engine oil leak
- Blower Motor
- 2013 a5 data log
- Selling Brand New in box CTS Turbo B8 A4/A5 2.0T FMIC Kit
- Audi s5 v8 2008
- Help. 2011 A5 premium 125,000 miles
- Auto transmission service
- Best turbo for 2013 A5?
- iD Forged 17"- 20" Japanese Inspired 1pc Forged Wheels
- 2011 A5 2.0 liter convertible
- New Vertini RFS2.2 RFS2.3 RFS2.4 19" and 20" Sizes
- WTB ko4. Best option?
- OBDII plug ins
- Error P012100 & p012300 please help
- 2.0T CAEB Build Guide?
- Most exotic sounding exhaust setup for RS5 (lambo, ferrari, 911 GT3 like)
- Help me understand "Specified charge" vs "Actual value"
- 2011 A5 heated seats issue
- 2011 A5 Cabriolet Trunk lid light issue
- Flywheel touching timing cover
- 2017 A5 MMI and GPS Database Update
- 2013 S5 Manual transmission issues (grinding)
- A5 coupe 2010 rear defroster blowing fuse
- A5 cabrio rear view camera
- Audi a5
- 2009 3.2L Timing chain
- rough shaking after axle breaking
- Coolant in oil 2010 S5, help!
- Just bought a 2011 A5 2.0 Quattro...
- About parts supply
- 2013 S5 Memory Seat Not Working, set button not illuminating
- Christmas Holiday Sale
- Portable Apple CarPlay
- RS5 B8 B8.5
- Audi RS5 Carbon Ceramic Brakes
- Checking options on car
- 2014 Audi S5 Advice
- DSG problem or something else any expirience ???
- Shift Fork Possible Issue?
- Fault Codes on DSG, and Some Question for Repair
- Updating 2012 A5 MMI 3G High firmware and maps
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- BLACK FRIDAY SALE,, SuperSprint Italy
- ZA: P179E - Unsure
- 2012 S5 Value Assistance
- Car diagnostic help
- Rough idle A5 B8 EA888 GEN2 2.0 TFSI
- Main Seal Leak on a 2014 S5
- 2013 b8.5 s5 limp mode
- Waited too long to replace shocks... ya think?
- 2011 A5 - preventative maintenance?
- 2014 Audi A5 Sportback rear left indicator bulb change (outer bulb)
- Ventilated Seat Cover Part #
- Forgedlite Wheels Black Friday Sale 11/6 to 11/27
- TTS supercharged s5 misfire issue
- Ignition coils / upgrade, plug heat range?
- Considering a problematic S5. Should I try my luck?
- Cruisw contril problem
- 2012 A5 Cabriolet Display options for Apple Car Play
- 2016 S5 Cabriolet Premium Plus
- Tire Rubbing Sound on Hard Cornering
- How much should I pay?
- CD won't eject
- Shock/Strut shock, confusion
- Headlight range control defective
- 2013 S5 Cabriolet fuel leak at engine
- A5 Vibrating noise coming from turbo area
- Fuel consumption problem
- 2013 S5 - Parking Brake Error after Pad Change and VCDS
- Rear dome lights mysterious behavior
- Rough shift
- Plastic pieces in supercharger
- Audi a5 2012 sb maps?
- TIRE PRESSURE MONITOR Sensors?
- NEW 20" Brada Wheels - CX1 AND CX3 FORMTECH Series
- UK: Coolant leak
- MMI Upgrade Question
- Powering a dash cam via the MMI port
- 2013 S5 - what tranny
- 2010 Audi S5 V8 wont crank
- 2013 RS5 Transmission Issues
- Upper timing chain cover for 203 Audi S5
- Dsg Service cost??
- Threads for pics of builds?!
- Audi A5 8T3 - Error after succesfully retrofit Audi A4 steering wheel
- 2013 Audi A5 No Crank, No Start
- RS5 Won’t Start Won’t Crank
- New S5 cabrio getting HORRIBLE MPH and gauge way off.
- Need heavy duty windshield wipers for snow
- 2015 A5 multiple airbag codes b10001b, b10021b, b101614
- CA: I want to Delete my Check Engine Light?
- Exhaust pipe sleeve reusable?
- B8 rs5 mmi switches to AV source automatically when using aux
- Issue with Amp 08 S5 Coupe
- Help removing 2 lower bolts rear wheel bearing
- Parking Assist Front Buzzer Location
- 2016 Audi A5 Concert Radio and factory amp Replacement and amp + sub install
- B&O door speaker blown
- 2008 S5 4.2 Ticking/Knocking
- '13 A5 Cabrio Power top won't close
- Brake Initialization Not Done
- A5 coilovers
- 2015 S5 Dynamic steering malfunction - 59k miles
- B8.5 S5 Rear Diffuser Help
- Repair manual
- American message board members.....
- 2016 a5 cabrio roof not secure error
- Multiple Misfires - CALA 3.2L V6
- Is there a SMALL key fob available?
- Power steering pressure
- Audi A5 Convertible, car won't start and rear parking brake locked and malfunction
- Rear Brake Wear
- Audi's definition of "normal operating temperature"?
- 2013 Audi S5 MMI stopped working
- Greetings from SuperSprint Italy
- 2013 audi s5 incredibly high pitched beep at start
- Issue installing rear camera in Cabrio
- 2014 S5 rear brakes
- Small leak error / higher than normal idle....
- 2013 A5 unknown wiring
- Audi S5 08 Facelift Conversion Xenon Issues
- 16 Audi S5 with a trunk that suddenly won’t open
- what choice (chip)??
- Question about the value of a 2013 S5
- Help! frustrating intermittent issue, no solutions!
- Where is the oil pressure regulation valve?
- Broken vacuum T joint connector
- S5 Coupe purchase advice needed
- Dead Battery After Using OBD Eleven
- All my coolant drained out after topping off and driving hard!??
- BRADA WHEELS - FORMTECH - Audi Fitment Available - Wheel Designers
- Competitive Prices on Vertini Rotary Forged Wheels - WHEEL DESIGNERS
- Best launch, for grins?
- Retrofit seats compatible?
- Installing alu kreuz-type x-brace on RS5 cab and ran into issue…
- To get more power HP
- Map update needed
- AWD in RWD
- Oil Consumption Variation
- Engine in dynamic while transmission in D mode
- Power seats installment
- mmi and radio receiver help!!
- help with radio receiver on 2010 s5
- Keys Locked in Trunk of Audi A5 Convertible-A Solution
- Audi RS5 Won't Start - Engage P or N to Start Engine
- DRC - was it not standard?
- Oil Leak Water Pump Drive Shaft
- Capristo exhaust on B8 RS5 Boston Metro West?
- All New Stance SF11 Rotary Forged - Light Weight Design - Wheel Designers
- 2014 A5 Headlight Question
- Looking for a 2015 RS5 Cab
- want photos for powertrain fluid service please
- ReDisc - Carbon Ceramic brake disc refurbishment, repair and upgrade
- A5 Gearbox/transmission issue
- Exhaust
- B8 coupe/cabriolet compatability
- "oil moisture valve cover".
- Can someone tell me what this is and how to replace it. 2012 Audi A5 quattro
- Reset the Check Engine Light?
- LT: A5 headlight assembly
- 2011 A5 Cabriolet resistor kit for reverse light
- SE: Where or can I get a dipstick for my car?
- 2010 3.0 TDI cooling fan staying on a lot more than usual
- Audi A5/S5/RS5 (B8) LHD RHD 2007-2016 radio stereo upgrade with 10 inch screen
- 2011 A5 Cabriolet Head Lights
- Coilover help
- Closing the luggage compartment with fob remote
- OIL Leak (Oil Cooling Line).
- LT: What are these behind back seats on cabrio ?
- What would you do (A5 Repairs)?
- Outside Temp Sensor Location (G17)
- 2014 audi A5 Mirror covers
- 20% off NEW D3S/D1S LEDs FOR 2023 –Bright - NO ERRORS - PLUG & PLAY - NO wires!
- Center resonator / silencer replacement
- Maintenance for 100k+ S5
- Random Engine Shut off while driving 2015 RS5 - fearing the worst.
- 2011 s5 3.0. Oil under super charger?
- EPC & Parking brake fault, car not starting.
- ReDisc - Carbon Ceramic brake disc refurbishment & repair
- B8.5 S5 Rear Badge Placement
- Audi s5 strange noise from front end
- Water Pump & Thermostat Replacement
- part number of orings on upper timing covers
- Are there Audi cermaic brake pads for 2015 Audi S5
- Did 35k serivce include DSG serivce?
- Could Really use some guidance!
- Driver door lost power after replacing the door speaker
- Wheels?
- S5 B8 heavy misfire low rpm
- 2012 S5 oil filter housing leak
- Newby help!?
- Audi A5 2010 B8 (Scary random Misfires)
- Wheel Color Change
- Order Genuine European Parts for B8.5 2014 Audi RS5
- RS5 B8 Belt Replacement
- Stiff steering?
- Buzzing/Humming sound from Bluetooth Adapter
- car and possible wind damage?
- Vossen Wheels Black Friday Starts 11/20 to 12/2 While Supplies last
- engine starts, runs on half the engine, then dies
- A5 engine swap
- UK: 2013 2.0 TDI Multitronic Auto
- 2011 S5 Purchase Advice
- Bigger Brakes on A5 1.8tfsi
- UK: 2008 Audi A5 not starting
- AT: A5 2.0TDI Engine code CGLC oil consumption
- Stereo Upgrade for 2013 Audi S5 Convertible?
- Picked up a sweet S5
- Service Interval Reset (Not via MMI)
- BLACK FRIDAY SALE 11/1 to 12/2 While Supplies Last - Stance Wheels
