View Full Version : Audi A3 / S3 / RS 3
- Honeycomb Fog Light Grills
- RS3 rear noise... gone when taking out fuse
- 2006 Audi A3 2.0t FWD Hose question
- A3 '06 8P Fuse F10?
- Advice on A3 1.8T engine rebuild/ replacement
- Cluster display issue - unable to start car
- PRNDS flashing gearshift codes
- Transmission Fluid Pump Module 'A Location
- Turbo issue but no limp mode?
- 2009 a3 engine bay loom diagram
- 2007 A3 8P Codes P0243, P0444, and P0033.
- A3 2018 ECU issues after Recall service done.
- Ecu swap audi a3 8p
- 2017 Audi A3 | top portion of head light went out | see photos.
- Brakes Audi A3
- Bluetooth connectivity with Samsung
- Audi A3 1.6 8P key turns to on but no reaction at all
- OBD code reader
- Hit a Pole in my Audi a3 2021 saloon. Will private garage void my warranty
- S3 scratch/restoration work
- Knocking noise from my engine, white smoke and coolant smoking.
- Install wireless Apple Carplay
- Hissing sound & loss of power
- 8Y RS3: What is this knocking sound by engine?
- Used RS3’s
- 20% off our bright D1S / D2S / D3S LEDs! These are brighter than xenon bulbs!
- Audi A3 2010 1.4L gear out of control
- 2012 Audi A3 2.0t EA888 Timing Chain
- Rough stuttering cold start on 2012 Audi A3 8P 2.0tfsi
- Audi a3 1.4 tfsi 2008 Power loss on 4th and 6th gear
- FI: 2014 A3 1.4 tfsi, can't connect to ecu after changing turbo
- Location of TCM / Car wont crank
- 8Y 034Motorsport Dynamic+ on locked TCU opinion request
- 2015 Audi A3 Misfiring under heavy throttle Any thoughts
- BA: US style blinkers sideffect HELP!
- A3 engine in s3?
- ESP activation, clicking noise, vibrations - investigation
- Audi A3 8L part
- When I press the gas pedal I hear a ticking noise
- 2.0 TFSI timing belt guide help
- UK: Multiple issues with A3 Quattro
- Intake flap
- COMM #
- Does anyone have a clue what this noise is? A3 8P 2.0 TDI
- How’s the backseat space in the 3/rs3 for kids?
- Front Camera location
- 2013 Audi A3Q (2.0) ISO part info to replace only leaking flex section in downpipe.
- 2015 A3 Quattro 6 speed auto DSG
- Electro- mechanical parking break
- Drivetrain Malfunction leading to check engine light
- EPC light came on (2016 Audi A3)
- Upper timing cover bolt won’t tighten to collar
- What is the hot part?
- 2018 A3 Headlight issue
- What is this 1.8T hose?
- 2015 Audi A3 Power Seats (SimRacing)
- Is there an alternator fuse on a 2016 Audi A3?
- 2001 Audi A3 8L A/C Pressure sensor location
- A3 8l ICM wiring diagram
- 2011 A3 2.0 TDI blowing black smoke
- "Tyre Pressure Cannot be stored at this time"? help!
- Is the USB fast charger PD100W+QC3.0 compatible with a 2017 Audi A3 cigarette port?
- anyway to fix center brake light? my A3 Quattro still runs good..
- Water ingress boot hinges ?
- Where can i find a light part for a Audi A3 E-Tron 2017
- Audi a3, mmi unit does not come out
- 2016 A3 Interior Handle Replacement.
- Audi Grille Question
- Transmission issue? Car won’t move in drive or reverse
- Audi A3 2020, doors compatibility
- ‘20 audi a3 Electronic Parking Brake not disengaging
- Removing Rear passenger side trims
- 2016 Audi A3 Quattro 8V Fuel Issue
- Flashing gear indicator
- Changing Steering wheel
- Install Cams and Time
- Wipers rest position.
- 2020 Audi A3 Oil level system malfunction! Please contact service
- No lights working on the boot it self.
- Armaspeed Luminous Paddle Shifters
- metal clip audi a3 2018 s-line
- B7 S4 Recaro to 8p A3 S-Line Retrofit
- ENGINE WON'T START - A3 2.0TDI quattro 140hp
- Part number problem
- Front registration plate stuck
- 2009 Audi A3 8P - Parts Car - $1,500 OBO
- Side(left) mirror is not heating
- A3 gas mileage
- Christmas Holiday Sale
- 06 A3 2.0T FSI (8P) ECM Power Relay Fuse Location??
- Audi a3 Quattro 8P tunning advise
- Mirror Phone/Video to MMI?
- Fuel System Issue (p0089)
- Car won’t move in neutral
- Weird heating problem??
- Connector in Glovebox in Audi A3 2015 1.4 TFSI Saloon
- Rs3 matrix water flow issuise help
- 2010 A3 Error Codes 7E8 and 7E9
- Audi a3 2002 1.8t aum engine
- 2021 Audi a3 steering juddering when turning at low speeds
- Audi A3 8V showing P0475, P0477 and P0477 HELP
- 2015 A3 Right side light/daytime running light
- getAudiparts.com | Black Friday/Cyber Monday '23 Savings are Live!!!
- BLACK FRIDAY SALE,, SuperSprint Italy
- BLACK FRIDAY SALE / CYBER MONDAY ON NOW @ deAutoLED.com – bright error free LEDs
- Crank End Bolt and Sprocket (that timing belt goes around)
- 1057803 antenna for keyless entry system in trunk open circuit fault audi a3
- 2.0t Fsi boost gurus
- 2012 Audi A3, TDI, Immobilizer issue
- 2013 A3 footwell lifghts?
- UK: We’re do I post for a rs q3 8u technical?
- Help Pls: Fault codes P2279, P0507, P2187
- License plate light screws
- Bought a 06 A3 2.0T front wheel drive from police auction
- Install New Oil Pump Chain
- 2009 audi A3 2.0 tfsi
- OBD2 readiness for NMHC catalyst on a TDI
- 2009 Audi A3 cranks but no start
- ***CALLING ALL MK5 GTI / A3 GURUS***
- G235 location on CJAA
- A3 door sensor removal
- UK: Audi A3 1.6 tdi 2016
- Replacing Oil Pump
- Audi A3 2009 8P drivers door and rear right passenger door not opening with fob
- How to know if the transmission is DSG?
- Audi A3 1.6 TDI (2010) Idle/Stall problem
- High Gloss Black Dash
- Where can I locate front rotor size 2011 a3 tdi s-line
- DPF Regen: repeat or delete?
- Prospective Audi A3 FWD Purchase
- 2015 Audi A3 parking brake issue.
- 06 a3 vr6 misfire
- 06 A3 8p Trouble Shifting Into Gear
- Coasting mode on Audi S3 8Y
- Adding a subwoofer.
- A3 Dash cam
- A3 door wiring rubber boot
- A3 Heated seats
- Audi a3 bkd smoking under hood and oil pressure light coming on
- 2008 audi a3 ignition terminal 30 issue, intermittent no start. No crank
- Audi A3 8P not starting with EPC ligth on
- DSG Transmission Oil flush procedure
- Spacers
- Need Help Identifying Part - Seal on Door Bottom
- Radiator fan keeps running
- Error on Audi A3 1.6TDI (P0341 P2127 P0651)
- 2009 Audi A3 2.0 Diesel strange buzzing sound under bonnet st idle
- Audi a3 2.0 tdi 2014 long crank before start in the morning
- Confusing Parasitic Draw
- Seat back bottom clips
- A3 8P missfire Roughidle Epc light?
- 2015 Audi A3 repairs
- LT: Cupholder compatibility between A4 (8D) and A3 (8L)?
- Replacing Adjust Motor Actuator
- 2010 a3 not starting
- Audi A3 - 2017 Oil Sensor Malfunction (HELP PLS!!)
- RNJ Performance
- Help with codes please (P509A, P4D5B)
- Only one code and I dont know how to fix it (17272 )
- Audi A3 2009 2.0T oil leak issues
- Cuoholders
- Overheating
- Audi A3 8v hvac problem
- Rear Camera Only Turns On When Trunk is Open
- 2009 A3 S Line Engine Swap Thoughts
- 2012 S3 Installing front springs - Ball Joint & Drop Link question
- How can I keep my car’s Bluetooth on but my whole car off? Audi A3 2015
- Where can I source this S3 wheel?
- A3 8P. ESP/ABS Fault Headlight range finder defective
- Wheel question.
- 2001 Audi A3 1.8t 8L - Fuel Consumption
- UK: Audi A3 2017 - Engine start system malfunction
- UK: A3 1.4 white smoke
- Audi rs3 engine wiring diagram
- UK: Audi rs3 engine wiring diagram
- Throttle actuator not 100% on WOT
- UK: S3 Engine seizure - what to do?
- Cam belt change. When to do it?
- IT: Audi A3 8P dual clutch throttle delay
- 2015 Audi S3 Clunk Noise in front end
- Oil magically disappears and reappears
- Chasing down CEL codes on a 2007 A3 8P
- A3 2.0 TDI BKD Crank, No start
- 2019 a3 rear calipers
- Audi A3 Sport (2023) vs Audi Q2 Sport (2023) As the title says, which out of these
- A3 tdi fan
- Mysterious issues with 2006 A3. Is this limp mode?
- Audi A3 8V (stronic) - Weird rhythmic noise.
- Want to use Synthetic Gearbox oil instead of recommended Mineral Oil
- Temp getting high
- 2007 A3 8P ignition barrel, switch and lock
- Do you know why
- Right front turn signal not working
- Audi A3 keypad rubber replacement
- NZ: 2006 Audi A3
- Hot Weather = Higher auto shift points?
- The Audi A3 is better than the S3 (Hear Me Out)
- 2016 A3 Cabriolet roof latch clunking sound
- Audi A3 2006 automatic won't activate D drive
- Rain Sensor
- Fuse issue
- 2018 Audi A3 Pre-Sense Malfunctioning
- Spare Key/Key Fob lost-Deactivate?
- American message board members.....
- 8p a3 Running lean with CAI
- Suspension leg replacement (Audi A3 2013)
- A3 8P (WAUZZZ8P97A162598) G65 SENSOR CABLE MELTED
- Audi A3 8p 2.0t Cranks but doesn't start P0016 and p0327
- UK: Engine fans running loud on idle, help!
- UK: A3 radio - intermittent on & off
- UK: Audi A3 8V (2018)
- rearend hit and run
- S3 8P(1) Transmission identification code and viability
- 2003 A3 Coilover Trouble
- So many errors all at once.
- SCR options
- S3 8P Cluster not working
- Audi A3 Transmission issues? orrrr...
- How Program Command
- Cold cranking issue, Audi A3 1.6 TDI 2014
- 2008 audi a3 1.9 tdi hot start problem
- Audi A3 2015 Sline Steering Wheel Issue flashing button lights
- Audi A3 transmission issue
- RS3 Apr stage 1 Tune
- Time to change timing etc belt Audi A3?
- Won't Start after Slipping on Brake During Start
- Greetings from SuperSprint Italy
- 8p audi a3 vibration
- 2017 A3 Quattro oil leak
- Replaced audi A3 2010 abs needs long coding
- stabilization control system(ESC) Problem
- UK: 8P 2.0TFSi quattro issue
- Audi A3 8P
- 2013 A3 2.0T FWD hvac issue
- Audi A3 8P ECM Relay? No Signal/Communication with ECM - Intermittent
- Clunking noise on front wheels when no weight on them
- WINDSCREEN REPLACMENT £620 WTF?
- Fusebox Wire
- A3 light bulb warning (bomb with X across it)
- Reset tire tpms sensor
- 2017 Audi S3 - Pulls Right After New Tires & Alignment
- Audi A3 8V Saloon Rear Window Regulator.
- 2.0T A3 - Car won't start unless I put in some throttle
- A3 fuel door won’t lock
- APR stage 1 with downpipe
- How to remove front license plate holder?
- Leaky 2007 Cabriolet
- Replacing key and cylinder - what do I need?
