- Help Please Major Coolant Leak : Front Coolant Crossover Pipe? Water pump replaced
- Fault P2227
- Possible Engine Rebuild After E40 Tune
- 2019 A3 purge valve replacement
- Weird RPM on cold start
- 2015 with P016, P0381 and P087
- 2015 Audi S5 3.0 TFSI rough idle / stalling?
- Audi B9 SQ5 knocking and hesitate
- B9 ROCKERS
- Swirl flap delete...?
- Buying advise 3.0 tsfi CREC
- 3.0 TFSI engine rebuild: interchangeability question
- Balance shaft timing help
- Running engine without supercharger
- 3.0T CREC Engine fuel smell
- 2016 A6 Piston and Rings rebuild
- please help to set EA839 3.0 timing gears
- 2019 A7 55 TSFI
- Audi S5 3.0 TFSI 2017 noise troubleshooting
- Modified A6 2014 drivability problems
- Check engine OBDEleven Log
- 68k Oil change analysis after 7.5k, Excellent results
- Metal in oil, horible knocking, 60000 miles
- [3.0 T/TFSI] Cold start engine sound - videos
- 3.0T Loud Tick...
- IL: 3.0T Engine swap?
- Allosun Fuel Injector Tester - Can't get it to work
- Audi a7 3.0t engine ticking
- New Project Car Reveal + Upcoming TT vs G35 Race
- DE: Timingchain keeps slipping
- AUDI Q7 3.0 Limp mode - every drive
- V6 "family" problem?
- Book labor time?
- Weird cold start
- 3.0T Supercharger cooldown?
- Mechanic in Fort Worth
- S5 coupe 3.0tfsi 333hp 2013 facelift stronic
- 2017 Q7 3.0 misfiring and oil consumption issue
- MOTOR MOUNT HELP Q7
- Does a rusted sleeve band clamp throw check engine light?
- 3.0 TSI on Q7
- Supercharger pulley size
- Lamda sensor error after new Fuel Pump
- P052E PCV malfunction 2013 Aufi A7
- White smoke
- How common are carbon deposits in the EA839
- Loud tapping at idle 2010 A6
- MTM cover under the hood
- Can chain upper guide rail cracked
- Purchase advice w 3.0T TSFI
- Front coolant crossover tube issues. Need help please!
- paddle shifters gears?
- 3.0 TFSI oil spec
- Avoid ECS Tuning oil change kits
- Audi 3.0 TFSI same as Porsche Macan S 3 liter?
- Timing Chain Tensioner failure.
- Audi S4 3.0 TFSI -10
- Which company produces OE waterpump?
- Smoking under hard acceration
- EPC light and cylinder 2 and 3 misfire
- 2012 C7 A6 3.0 Prestige stage 2 white smoke/pcv? Or intercooler?
- Chirping/ squeaking noise
- Have 2009 A6 SLine Quattro ,
- S4 TFSI 3.0 Supercharger/intercooler problem
- P168D Fault
- Cylinder 3 misfire - AWFUL 3.0tfsi
- 2015 A6 error P0090 Fuel pressure solenoid up
- Blown Head gasket After thermostat/ water pump replacement..
- 2013 audi s5 cooling fans on while engine is off (3.0 tfsi supercharged)
- 2012 Q7 S line P0018 code
- Running Seafoam Spray through supercharger intake?
- 2018 SQ5 3.0 TFSI water temperature !
- Check Engine oil Problem!!!!
- Are all 3.0T's interchangable?
- 2011 Audi Q7 3.0L Gas Engine High Oil Consumption
- Please help on coolant hose replacement
- Noise from supercharger
- Vibration on acceleration
- 04 A4 3.0 Overheating issue
- 2013 Audi 3.0 TFSi Blow Piston Rings, Engine Write off
- supply injection valve electrical fault audi q7
- My car shakes when not push gas
- B8.5 S4 - Coolant System Failure (help)
- oil grade
- FLush coolant Pricing issue
- 2018 audi q7 engine 3.0 l v6 clunk nose
- ENGINE KNOCK/CLICKING HELP!!! B8.5 S4
- Oil pan replacement on my 2003 A6 3.0
- 3.0 TFSI Airbox Cover and Intake Help/Questions
- Q7 3.0T Coolant Refill Question - Auxiliary Pump
- B8 S4 DSG Engine Startup Rattle
- Audi A6 3.0T Throttle Issue
- Excessive Fuel in Oil in Cold Climates C6 A6 3.0T
- Anyone else have a rear main seal go?
- 2006 4.2 A8L timing chain maintenance
- how about this Car Obd2 brake Diagnostic Tool for Audi ?
- White smoke coming from engine bay 03 a4
- Crank no start diagnostics - HELP ME!!!
- Over heating
- Over heating
- Audi A4 avant 3.0 tfsi 272hp
- q7 2011 overheating
- A6 3.0 TFSI intake flaps issue. Code P2007/2008
- 3.0 TFSI Audi S4 B8.5 - Engine is too hot
- Vibrations when turning with AC on
- Multi tronic issue
- Donor - 3.0TFSI to 818
- Check Engine Light after T-Stat Replacement
- Low coolant
- cgxb vs ctua
- P0491
- Audi S4 2011 3.0t compatible with Audi A6 2013v
- Q7 3.0T premium vs Prestige
- 3.0T Tune - what else?
- please help car misfiring engine management lights flashing
- 3.0 engine swap awd to fwd
- Just bought a 2012 S4 with 27000 miles, 1 week later oil leak
- 2010 Audi A6
- Horsepower boost
- Mild vibration and idle sound
- 2002 Audi a4 Quattro 3.0
- 3.0T Higher Miles
- Multiple malfunctions! Epc, sport differential, parking brake, and low tire warnings
- Serpentine belt diagram
- Audi C7 3.0L engine tap cold start
- Horsepower boost
- 3.0 HP
- Drain plug gasket
- Oil pump replacement help!!!
- P0018 - Check engine light
- S4 startup rattle
- Oil recommendation
- Help to determine BOOST on 3.0 TFSI
- car struggles to turn on??
- Tune-up? oil change?
- My Serpentine belt keeps ripping!
- P0241 & P0240 Turbo/Boost Pressure Sensor intermittent
- 3.0TFSI Service Manual still out there?
- 3.0 TFSI dimensions
- Audi Q7 2011 3.0 TFSI Overheating
- A6 3.2 fsi Quattro temp sensor location
- Octane
- Front Motor mounts
- engine/exhaust vibration at 1200 rpm
- Intercooler upgrade and bleeding the system
- Oil Catch Can on new 3.0t?
- 3.0 Tfsi carbon build up: yes or no ?
- :: ECS Tuning :: Schwaben European Essentials Tool Sets!!
- :: ECS Tuning :: Pentosin - Superior Fluids For Your Audi
- Is the 3.0TFSI really that "de-tuned" from the factory?
- APR Pulley Upgrade
- Differences between the 3.0TFSI flavours?
- Why is this forum so dead?
- California Emissions
- APTuning Black Friday Weekend Sale - Custom Euro Plates - APR - United Motorsport
- All Carbonio Carbon Fiber Intake Systems Currently In Stock and On Sale at APTuning!!
- Back In Stock: B8 Carbonio Intake Systems @ APTuning w/ Free Shipping!!!
- FSI DI engine carbon problems impacted by motor oils???
- engine noise after thermostat. replasement
- APR Summer Sales Event, Now Happening at APTuning!!!!
- Now Available: B8 S4 Carbonio Intake Systems @ APTuning w/ Free Shipping!!!
- Do i need to let the car idle afterwords to "cool down" the supercharger
- APTuning/APR December to Remember Holiday sale!!!
- Where is the advantage of the SC?
- Tuning 3,0T
